Re: Need help with my 22r carb on 88 toyota truck [Re: thenightrider33] #1039469 12/30/11 03:46 AM
kewlynx Offline
Make sure your stuff is hooked back up properly first. The dashed lines are for stuff that isn't required (like the HAC).
Your fuel hoses could very well be swapped also as suggested; gotta love using digital photography before tearing into stuff.
**ubi apis- ibi salus**
Re: Need help with my 22r carb on 88 toyota truck [Re: thenightrider33] #1039470 12/31/11 02:54 AM
Cholltero Offline
If you have fuel in the bowl it's a pretty good indication your pump is at least working a little .
I'd be checking my timing and in particular the Vacuum Advance once you square away your fuel concerns.
85' 4x4 e-cab flatbed 22r carb ((SOLD))
86' 4runner, 22re , "60 buck truck"
95' 4runner, 22re,5sd, last of the good ones
02' Tacoma prerunner, 2.7L, 5spd., 4x4
Re: Need help with my 22r carb on 88 toyota truck [Re: thenightrider33] #1039471 01/04/12 04:51 PM
djordan6319 Offline
I would check fule filter and possibly fule pump along with Throttle possition sensor not sure if your truck has one I think it might tho
Re: Need help with my 22r carb on 88 toyota truck [Re: djordan6319] #1039472 01/05/12 02:37 AM
kewlynx Offline
Carb'ed rig, hence no TPS. <img src="/forums/images/graemlins/wink.gif" alt="" />
Re: Need help with my 22r carb on 88 toyota truck [Re: kewlynx] #1039473 01/05/12 03:47 AM
CJM Offline
I would check for vacumme leaks .. a can of starting fluid sprayed on gasket seams and hoses will confirm ..
but be carefull if you do this .. highly explosive , so NO SMOKING !!
83 Trekker SR5
NEW Trekker forum
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.006s) Memory: 0.6123 MB (Peak: 0.6768 MB) Data Comp: Off Server Time: 2026-11-02 12:28:14 UTC
