Update to slight miss, more questions! (Update 2!)
#1039574
12/27/11 06:46 PM
Ok, more info to help diagnose this.
#2 Cylinder is dead at idle, but sparks starting about 1500rpm...even then though it's got a slight miss til redline.
Distributor?
ICM?
Anything?
1989 Raider SWB Auto 3.0L...It's ALIVE! Currently on a shakedown cruise...
Re: Update to slight miss, more questions!
[Re: dougl3nc]
#1039575
12/27/11 06:48 PM
Is there some crude on the inside of the dist cap? Thats the only thing I can think of if all the other cylinders are firing correctly.
[Re: dougl3nc]
#1039576
12/27/11 07:07 PM
Yup if everything else is firing right then my guess would be... plug, wires, or dist cap.
Based on my 'limited' understanding an ICM issue would affect all cylinders not just one.
[Re: off-roader]
#1039577
12/28/11 04:02 AM
How about a bad ignition wire?
[Re: rxinhed]
#1039578
12/28/11 04:20 AM
Bosh "lifetime" wires fall apart like wet spaghetti.
[Re: rxinhed]
#1039579
12/28/11 04:57 AM
If you have enough slack...move the #2 wire somewhere else. If the miss follows;then you've found the problem.If not the trouble lies w/ #2....
Va_Stumpy 89 Raider "Never judge horsepower by exhaust" 3.0 automatic stock as a rock Dual Bouncy Seats
[Re: Va_Stumpy]
#1039580
01/06/12 03:30 AM
Turns out that the optical eye in the 89 distributor controls the trigger of the fuel injectors as well as ignition...in a most precise manner at that!
Bought a remanufactured Distributor thru AutoZone, installed it, and now it runs PERFECT! $150 thru my commercial account, not bad when there aren't many options.
