4wd vibration
#1040211
01/13/12 03:29 PM
had a bit of snow up here in maine. I locked the hubs "warn" shifted to 4wd high. went to work no problems. 8hrs later going back home i feel a slight vibration then a grinding noise. Before winter i took the hubs out cleaned them relubed them. also replaced wheel bearings and seals. i know its not the brakes cuz i replaced them this summer. sooo what ya think.
if speed kill do brakes give life?
Re: 4wd vibration
[Re: snowboardvdr]
#1040212
01/13/12 10:26 PM
Check your u-joints, I just got to change one myself.
Re: 4wd vibration
[Re: bingocouple]
#1040213
01/15/12 04:11 PM
probably the u joints on the lockers. also - check the driveshafts - are they balanced?
2001 sporty. 4 inch lift+ body lift-front lovlells coils+extended forks. reat tj. monroe shocks. full skid plate, auxilary fan. external oil cooler. maxxis 8060 235/75 R15 tires on american racing wheels. trackfinder rear diff lock. http://www.cardomain.com/ride/3948684/2001-kia-sportage
Re: 4wd vibration
[Re: hadtomer]
#1040214
01/19/12 01:48 PM
well looks like i need to replace the u joints. my mechanic says the drive shaft is good. had to replace the drivers side wheel bearings. wasnt greesed good enuff. funny cuz thats the side he did. didnt have to pay for it he did. so i will be checking rock auto for parts.. thanks for the input guys..
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.5970 MB (Peak: 0.6521 MB) Data Comp: Off Server Time: 2026-06-17 13:37:35 UTCValid HTML 5 and Valid CSS
