Page 17 of 20 1 2 … 15 16 17 18 19 20
Re: 3.15 T-case gears or Possible group buy [Re: MontyMcV] #1040431 10/30/12 04:03 PM
At these prices you could swap in a Rocktrac 241 and have 4:1. On the high side you could spend 4k and swap in an Atlas 4 speed, I learned that the Atlas 2 speed and Stak 3 speed are to short to allow driveshaft/T-bar crossmember clearance on a LWB obviously it can be done on a SWB with IFS.
Re: 3.15 T-case gears or Possible group buy [Re: TOASTY] #1040432 10/30/12 09:35 PM
Ian Sharpe Offline
Toasty, surely the Atlas 4 speeder would be more that $1400! & how would it mate to the tranny?? & how would you run the speedo?? No doubt the Active Trac would be lost too.
97 Exceed, 3.5l SOHC auto, 4.90 gears, ARB front locker,rear Harrop E-Locker, Magnum winch, dual transfer cases also 2008 NS swb Pajero, front bar & winch
Re: 3.15 T-case gears or Possible group buy [Re: Ian Sharpe] #1040433 10/30/12 09:50 PM
Ian Sharpe Offline
sorry mate just realised you said $4k for the Atlas, anyway still interested in how it could be done.
Re: 3.15 T-case gears or Possible group buy [Re: Ian Sharpe] #1040434 10/30/12 10:55 PM
justice Offline
Tailhousing from a Jeep Cherokee bolted to the AW3 trans, and order the Atlas with 23 Spline short shaft would be my guess. Same way they hooked up the 241 rocktrack to Lloyd's rig.
If these gears don't pan out for a decent price, I'll probably go with the 4 to 1 rocktrack myself.
Re: 3.15 T-case gears or Possible group buy [Re: justice] #1040435 10/31/12 12:36 AM
If you want 4hi for the street, use a 242j with an aw3 jeep tailhousing on the mitsu trans. It's as strong as a 231 but it has a center diff, which locks in 4lo or 4hilocked. You may be able to use a 231 front case on a 242, too. The 242 has about a 2.85 lo range, and may well be able to fit a lot 0f 231 gears, but I'm not sure of that. May be able to fit the 241OR 4.0 gears.
Re: 3.15 T-case gears or Possible group buy [Re: fasteddy] #1040436 10/31/12 08:55 AM
Ian Sharpe Offline
Re: 3.15 T-case gears or Possible group buy [Re: justice] #1040437 10/31/12 01:11 PM
Angelo Offline OP
I don't think the price is going to get much cheaper than what's listed above. Let me know if you want to stay on the list so I can update the final list. Magic number is 10
Re: 3.15 T-case gears or Possible group buy [Re: Angelo] #1040438 10/31/12 02:43 PM
Lloyd Swartz Offline
Keep in mind the Rock Track is NOT CHEAP. Use T/case command 650-1100. I got mine for 650.00 but I think they made a mistake. They are in huge demand. Then you need a 140.00 shift kit, then a 200.00 speedo kit(if you get the wrong one) then 650.00 in new drive shafts, I forgot what the adapter was...Yes you get lower gearing, but it is really more expensive as I found out.
Re: 3.15 T-case gears or Possible group buy [Re: Angelo] #1040439 10/31/12 03:46 PM
justice Offline
Still in. T-case mod wont happen untill after 4.90's anyways. So keep me on the list untill the dust settles.
Re: 3.15 T-case gears or Possible group buy [Re: justice] #1040440 12/08/12 03:27 PM
Angelo Offline OP
EDIT: updated list
3.15 Auto
1. 99montero- Angelo
2. jinstv
3. Carlos
4. Kirk
5. Bullworker
6. Bullworker (maybe)
7. Justice
8. Cowboy Dave
9.
10.
3.15 Manual
1. 03GallagherJ
2. Stevie-Ray
3. NJV6 (Oz Pajero forum)
4. Bigfella78 (pending on scaring his wife)
5.
6.
7.
8.
9.
10.
PHP: 7.4.33 Page Time: 0.013s Queries: 15 (0.009s) Memory: 0.6519 MB (Peak: 0.7605 MB) Data Comp: Off Server Time: 2026-10-24 07:17:11 UTC
