Page 18 of 20 1 2 … 16 17 18 19 20
Re: 3.15 T-case gears or Possible group buy [Re: Angelo] #1040441 01/10/13 01:00 AM
Angelo Offline OP
Bump for new interest. Just need 10 of either to get it started
Re: 3.15 T-case gears or Possible group buy [Re: Angelo] #1040442 01/10/13 09:31 PM
Angelo Offline OP
EDIT: updated list
3.15 Auto
1. 99montero- Angelo
2. jinstv
3. Carlos
4. Kirk
5. Bullworker
6. Bullworker (maybe)
7. Justice
8. Cowboy Dave
9.
10.
3.15 Manual
1. 03GallagherJ
2. Stevie-Ray
3. NJV6 (Oz Pajero forum)
4. Bigfella78 (pending on scaring his wife)
5. KingBrown- CJ
6.
7.
8.
9.
10.
Re: 3.15 T-case gears or Possible group buy [Re: Angelo] #1040443 01/28/13 09:15 PM
Angelo Offline OP
Ok, next stage update!
I'll post more details when I get back home but basically we got nearly 17-18 and the company willing to purchase the rest to make it work said he is ready!
So now it's time to put your money where your mouth is. Email me your info and I'll pass it along to Rodney. He will need $450 deposit and the rest at a later date.
Like I said, I'll give more details when at home, hopefully this evening. So don't make me hunt you down <img src="/forums/images/graemlins/mrt.gif" alt="" />
Re: 3.15 T-case gears or Possible group buy [Re: Angelo] #1040444 04/10/13 08:37 PM
Angelo Offline OP
Wow, I really dropped the ball on this one.
Been super busy with life in general.
So back on topic and getting the ball rolling again. The ones that were interested and on the list, could you guys please send me your contact info and let me know if you are still on or off the list. Had a couple people contact me on the Pajero site and they are ready to move forward.
What other info do the ones on the list need from me? I'll hopefully have an up to date list here soon <img src="/forums/images/graemlins/ignore.gif" alt="" />
Re: 3.15 T-case gears or Possible group buy [Re: Angelo] #1040445 04/10/13 09:09 PM
Just go buy a different T-case, 3.15's are OK but they kind of fall in between 2 more useful ranges those being 2:1 and 4:1. You end up loosing a good cruising low range and they still stall out during more technical crawling, i think stock or 4:1 would be better depending on how you wheel. If your wheeling style is more diverse look into an Atlas 4 speed or Stak 3 speed, if you're on a budget go with a doubler/D300.
Re: 3.15 T-case gears or Possible group buy [Re: TOASTY] #1040446 04/11/13 01:40 PM
Angelo Offline OP
I hear ya toasty! When it comes to all that custom stuff, I'm dead in the water. Unless its more straight forward than the 3.15 swap or someone that lives close to me could help, then 3.15's would be my direction, for now.
With that being said, the people on the list below need to send me their info so I can pass it along. If you are no longer interested, let me know so I can update the list.
Some had to pull out due to other important things. So don't feel bad if you need to step down off the list
Updated list below:
3.15 Auto
2. jinstv
3. Carlos
4. Kirk
5. Bullworker
6. Bullworker #2(maybe)
7. Justice
8. Cowboy Dave
9.
10.
3.15 Manual
1. 03GallagherJ
2. NJV6 (Oz Pajero forum)
3. Bigfella78 (pending on scaring his wife)
4. KingBrown- CJ
5. BundyJr
6. Tritonmea
7. DocBassett- Mitch (New Triton forum)
8.
9.
10.
Re: 3.15 T-case gears or Possible group buy [Re: Angelo] #1040447 04/11/13 09:45 PM
Canyonero Offline
I'm afraid I'm out for now. Too many financial obligations at the moment, and for the foreseeable future. <img src="/forums/images/graemlins/angry.gif" alt="" />
I'm #3 on that list. jinstv. changed my username.
1995 Montero SR
2" Body Lift
35x12.50x15 Cooper Discoverer STT
Aisins
Re: 3.15 T-case gears or Possible group buy [Re: Angelo] #1040448 04/12/13 12:31 AM
Ian Sharpe Offline
yeah but we all know about that bad arsed cross member that stuffs everything up!
97 Exceed, 3.5l SOHC auto, 4.90 gears, ARB front locker,rear Harrop E-Locker, Magnum winch, dual transfer cases also 2008 NS swb Pajero, front bar & winch
Re: 3.15 T-case gears or Possible group buy [Re: Ian Sharpe] #1040449 04/12/13 04:39 AM
It's not too bad, I modified a stock T-case mount to work with the NV241 transfer case. The bad thing with the Gen 2 is you need to run the larger cases othewise the rear drive shaft because it hits the torsion bar crossmember.
Re: 3.15 T-case gears or Possible group buy [Re: Canyonero] #1040450 04/12/13 05:07 AM
Angelo Offline OP
No problem. Just keep in mind that this may very well be the last batch of 3.15's ever. Rodney is only taking the deposit up front. The rest is paid after they are done, most likely a month or two later. Either way, I'll remove it & if you change your mind, you know where to find me <img src="/forums/images/graemlins/kewl.gif" alt="" />
Updated list below:
3.15 Auto
2. Carlos
3. Kirk
4. Bullworker
5. Bullworker #2(maybe)
6. Justice
7. Cowboy Dave
8.
9.
10.
3.15 Manual
1. 03GallagherJ
4. KingBrown- CJ
5. BundyJr
6. Tritonmea
8.
9.
10.
PHP: 7.4.33 Page Time: 0.012s Queries: 15 (0.009s) Memory: 0.6549 MB (Peak: 0.7610 MB) Data Comp: Off Server Time: 2026-10-22 02:20:26 UTC
