Re: 2.6l montero highway speeds and rpm [Re: off-roader] #1040930 01/27/12 07:33 PM
Grasscat Offline
The stock Mikuni carb is a POS, and has a rat's nest of hoses associated with it. All the more reason to junk it and replace it with a Weber 32/36.
Not when they're set up properly w/out leaking vacuum lines which IIRC is the number one problem other than some bozo not hooking the lines up correctly.
I agree with Ray. There are millions of those carb's out there and if properly tune they are just fine. Reminds me of my days dealing with the Volkswagen bug, gotta change the carb to a Weber or it won't run right. BS
Michael j
TreadLightly! Trainer
Re: 2.6l montero highway speeds and rpm [Re: Grasscat] #1040931 01/27/12 08:17 PM
L
Lifecast Offline OP
I just wish the repair manuals were specific where each one connected too so I can go in a organize the vacuum hoses. Right now it looks like spaghetti and I'm not sure if they are in the right place. I guess I'll go in this evening and go through it. I do plan to get the weber but not for a few months and just to get rid of all this hoses that just confuse me. Probably also make it easier to work on the engine.
I just hope those empty vacuum ports on the carb are suppose to be that way.
Dennis
New to me , used 1987 SWB Montero 2.6l 4cyl auto. Stock so far.
Non Daily Driver, Not yet anyways.
Re: 2.6l montero highway speeds and rpm [Re: Lifecast] #1040932 01/28/12 12:56 AM
socal1200r Offline
Before (rat's nest):
After (vacuum advance and fuel lines, that's it):
You'll be MUCH happier with the Weber...
1989 Monty SWB, 2.6L w/MT, 15" alloys, 265/75 Dunlop Radial rovers, rear air shocks, Weber 32/36, SQ oil cooler, (SOLD Oct 2012)
Southeast VA, USA
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6021 MB (Peak: 0.6560 MB) Data Comp: Off Server Time: 2026-06-07 05:59:39 UTC
