Re: AIR BAG LIFTS [Re: off-roader] #1041201 02/01/12 03:49 PM
EDWINWKU Offline OP
so for about 200 bucks i can lift 2-3 inches? with these air bags and tighten the torsion bars. hmmm....worth a [email]shot@![/email]
Re: AIR BAG LIFTS [Re: EDWINWKU] #1041202 02/01/12 05:12 PM
Does anyone know if the air lifts that have the bags that go into the coil springs actually lift the truck or if they just reduce sagging with heavy loads?
I have air bags on my Gen 1 that I used for leveling the ride when towing trailers. The ride when empty sucked, The ones I had would not lift the rear much and when there was enough air in them to lift the truck the spring rate was stupid high, the articulation was gone.
Re: AIR BAG LIFTS [Re: off-roader] #1041203 02/01/12 06:00 PM
0778drz110 Offline
with a gen 3 independant front suspension how would I raise the front also? bigger struts?
Torsion bar crank will get you ~2" which also means a slightly stiffer front suspension and less articulation than when left stock. That said its a VERY effective way to do a front end suspension lift. <img src="/forums/images/graemlins/kewl.gif" alt="" />
On a gen 3 you need bigger struts, but since you have a montero sport all you need is a torsion bar crank.
Your montero sport is not a gen 3 montero. Its a mix of gen 1 and 2.
Re: AIR BAG LIFTS [Re: 0778drz110] #1041204 02/01/12 09:09 PM
mxmikie Offline
funny ... i was outside loading up my trailer for my once a year scrap haul and what do i find ???...... yep a new set of air lift air bags i cant fathom what i should do with them ...... any body have any ideas ???
Re: AIR BAG LIFTS [Re: mxmikie] #1041205 02/01/12 09:44 PM
EDWINWKU Offline OP
hmmmm what ya want for'em?
Re: AIR BAG LIFTS [Re: 0778drz110] #1041206 02/01/12 09:47 PM
EDWINWKU Offline OP
oh ok i guess thats better.....less money spent means more towards other stuff.
Re: AIR BAG LIFTS [Re: EDWINWKU] #1041207 02/01/12 10:11 PM
mxmikie Offline
ring ring... this is edwins fone he aint here.................
Re: AIR BAG LIFTS [Re: EDWINWKU] #1041208 02/02/12 07:44 AM
KrzyDav Offline
go with Gen2 coils for an inch of lift,,,,go with the Old Man Emu springs for sale in parts bin (mine) if you want even more lift and no sag for towing.
dave h.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6285 MB (Peak: 0.7117 MB) Data Comp: Off Server Time: 2026-06-23 00:45:44 UTC
