AIR BAG LIFTS #1041191 01/31/12 09:15 PM
EDWINWKU Offline OP
Does anyone know if the air lifts that have the bags that go into the coil springs actually lift the truck or if they just reduce sagging with heavy loads?
Re: AIR BAG LIFTS [Re: EDWINWKU] #1041192 01/31/12 09:46 PM
TainterRacing Offline
I am not 100% sure but I think it just reduces the sagging and ups the load limit. I might be wrong tho.
1997 Montero LS with a motor swap a 1990 V6 12valve ported heads full 2.5in Ex I run stock tire size for Daily use, off road have 33x12.5 working on going trubo.
Re: AIR BAG LIFTS [Re: EDWINWKU] #1041193 01/31/12 09:56 PM
EDWINWKU Offline OP
yeah i kinda figured thats what they did. hmmm....seems like im gonna have to go custom on the lift....
Re: AIR BAG LIFTS [Re: EDWINWKU] #1041194 01/31/12 11:16 PM
seely Offline
You can get an inch or so going to Gen 2 coils, I believe, if you have a Gen 1.
Third times a charm.
Re: AIR BAG LIFTS [Re: seely] #1041195 01/31/12 11:49 PM
87monty Offline
This is what I use on my rig and tow a offroad trailer They kick but and install easy! <img src="/forums/images/graemlins/smile.gif" alt="" />
Link:
http://www.autozone.com/autozone/parts/G...45_116379_6636_
2003 limited 20 year anniversary
96 SR
87 Montero SWB=Turbo diesel 4BT
T19 4sd with 205 transfer case
Re: AIR BAG LIFTS [Re: EDWINWKU] #1041196 02/01/12 03:05 AM
sasnydley Offline
I put them in my gen 1 like 6 yrs ago. They just recently split died... Gonna get some replacements. mine came with some rubber pucks approx 1 1/2 inch thick. I think this was for another application. but in my truck even with the front cranked I could easlier raise the rear 3 inches or more. So with the pucks yes they will raise it. I think you need to get the pucks separetly.
Re: AIR BAG LIFTS [Re: sasnydley] #1041197 02/01/12 02:31 PM
EDWINWKU Offline OP
If I can gain 2-3 inches by installing them. Their only like 100 bucks. hmm....worth a shot i guess.
Re: AIR BAG LIFTS [Re: sasnydley] #1041198 02/01/12 02:55 PM
EDWINWKU Offline OP
with a gen 3 independant front suspension how would I raise the front also? bigger struts?
Re: AIR BAG LIFTS [Re: EDWINWKU] #1041199 02/01/12 03:15 PM
Torsion bar crank will get you ~2" which also means a slightly stiffer front suspension and less articulation than when left stock. That said its a VERY effective way to do a front end suspension lift. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: AIR BAG LIFTS [Re: off-roader] #1041200 02/01/12 03:38 PM
EDWINWKU Offline OP
awesome! thanks!
PHP: 7.4.33 Page Time: 0.802s Queries: 16 (0.005s) Memory: 0.6357 MB (Peak: 0.7602 MB) Data Comp: Off Server Time: 2026-06-23 03:52:49 UTC
