Re: Daily Highway driver? [Re: Kevin C] #1041239 02/01/12 06:05 PM
0778drz110 Offline
I drove my 2.6/5speed on a 750 mile trip going 75mph the whole way. Something is wrong with yours if you can't do 65. My truck could still squeeze out 65 with stock gears and 38s. I would adjust the timing. Check the vacuum advance also.
Maybe you have head winds every time you go to and from work slowing you down. <img src="/forums/images/graemlins/lol.gif" alt="" />
Re: Daily Highway driver? [Re: 0778drz110] #1041240 02/01/12 06:35 PM
Way back when my Gen 1 was young, I had similar issues with not being able to maintain speed. The problem in mine turned out to be a bad fusable link at the battery. When the engine was under load electrical power was reduced to the ignition. I have replaced the fusable like in that truck 4 times for the same problem. It is hard to think I am the only one with failing fuse links causing undiagnosed power losses.
On an offshot when the engine is idleing wiggle the 3 link wires coming off the battery to see if the engine falters. The wire fatigues inside the insulation.
Kevin, I had not noticed the different OD ratios for the lockup transmission. I would love to find a closer ratio for the top gears in the SR transmission, that needs a fix more than anything I have driven in the hills lately.
Re: Daily Highway driver? [Re: OldColt] #1041241 02/01/12 06:55 PM
TainterRacing Offline
An Auto montero is going to be about 500-600rpms less in overdrive then what a 5 speed is in 5th. An Auto has more drivetrain loss as well. What size tires do you have?
1997 Montero LS with a motor swap a 1990 V6 12valve ported heads full 2.5in Ex I run stock tire size for Daily use, off road have 33x12.5 working on going trubo.
Re: Daily Highway driver? [Re: OldColt] #1041242 02/02/12 04:53 AM
I just did this yesterday by accident and my 88 did the faltering thing. Am going to look at it this weekend. Never thought about it robbing power. Thanks.
Re: Daily Highway driver? [Re: OldColt] #1041243 02/02/12 05:08 AM
Yep. I just came back from a camping trip in my '95 and pushing 35's and a loaded cab up to 6500+' really shows off how hard the 'platform' has to work. There's a lot of gear-hunting and obviously way-mis-matched gear ratios for the application. 5.29's would probably be in my best interest, if obtainable/installable/durable/"affordable".
Re: Daily Highway driver? [Re: JohnnyBfromPeoria] #1041244 02/02/12 05:53 AM
Depending on the engine mileage, you could be running into things like stretched timing chains, worn guides, etc. that affect the overall engine performance. Even with a blown headgasket and a shortblock that used oil, I had no difficulty maintaining 65 mph with my Raider.
PHP: 7.4.33 Page Time: 0.023s Queries: 15 (0.017s) Memory: 0.6198 MB (Peak: 0.7082 MB) Data Comp: Off Server Time: 2026-11-20 00:38:05 UTC
