Page 2 of 3 1 2 3
Re: CRAP! Major sunroof frame rot... [Re: seely] #1041270 02/02/12 04:46 AM
TainterRacing Offline
Welll you could go Mall.. LOL sorry I could not help myself.
I I have a car that the sunroof leaks I bet I need to do the same thing to it.
Well if you need some help I have plasma cutter and mig wielder. Would have to be more like the spring tho.
1997 Montero LS with a motor swap a 1990 V6 12valve ported heads full 2.5in Ex I run stock tire size for Daily use, off road have 33x12.5 working on going trubo.
Cleaning Sunroof Drains [Re: off-roader] #1041271 02/02/12 04:48 AM
I use my blow gun off my compressor for the front drains from the top (with the sunroof open) and hit the back two drains the same way, but from the bottom of the rear tubes, behind the rear tires. Works for me on my '95.
Re: CRAP! Major sunroof frame rot... [Re: TainterRacing] #1041272 02/02/12 05:00 AM
seely Offline OP
Ha. Ha. <img src="/forums/images/graemlins/nana.gif" alt="" />
Thanks! I may take you up on that... I may hit the yards and see what I can find for a replacement, though. I'm afraid all the ones in yards around here will be just as bad, though, so we'll see!
Third times a charm.
Re: Cleaning Sunroof Drains [Re: JohnnyBfromPeoria] #1041273 02/02/12 07:39 AM
Canyonero Offline
John, you're going to have to show me that trick the next time we hang out. Preferably when I have a running Montero (soon I hope). I've got some major sunroof stickage going on, and need to clean, lube, and learn where these drain points are.
1995 Montero SR
2" Body Lift
35x12.50x15 Cooper Discoverer STT
Aisins
Re: CRAP! Major sunroof frame rot... [Re: seely] #1041274 02/02/12 09:32 PM
seely Offline OP
Pic of the damage... thoughts?
Pic of damage [Re: seely] #1041275 02/02/12 10:14 PM
seely Offline OP
Re: Pic of damage [Re: seely] #1041276 02/02/12 10:44 PM
METALMOVER Offline
I think Id go to a windshield installation shop and have them take a look at it, maybe they can make you a custom gasket.Otherwise I think youd be looking at a new/used frame and glass. I know on a lot of vehicles the sunroofs are touchy and parts are expensive. Good luck
1987 Raider,2.6,mt,78"Meyer snow plow,100lb. Doberman alarm,weber carb, lockouts from here- 1989 V-6,SWB, A.T. 4x4, 31'S
Re: CRAP! Major sunroof frame rot... [Re: seely] #1041277 02/02/12 11:55 PM
P
pcc Offline
Several years ago I did a major fix on my sunroof. The problem is the window frame has a cupped "U" channel around the edge that collects water, salt etc., very bad design.
I pulled the glass and frame out and bought a new factory seal. I then attacked the rust with wire brush and sandpaper and used one of those rust-turned-to-primer treatments and painted with rust paint. Used silicone seal to attach the seal and reinstalled.
The drains can be flushed with water from the bottom, or air or a probe. Here we get Mud-dauber wasps which build clay homes in the drains.
Re: CRAP! Major sunroof frame rot... [Re: pcc] #1041278 02/03/12 02:12 AM
seely Offline OP
Any tip or trick to removing the the sunroof?
Re: CRAP! Major sunroof frame rot... [Re: seely] #1041279 02/03/12 03:31 AM
haztoys Offline
You poor guys in the rust belt ...
"I" would just go on vacation and drive to see sunny Arizona and get the sun roof for $40 here in Prescott at the junk yard.. Maybe see the Grand Canyon too..Bring the famliy .. <img src="/forums/images/graemlins/smile.gif" alt="" />
David
Hazardous Toys inc
Page 2 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.010s Queries: 15 (0.006s) Memory: 0.6431 MB (Peak: 0.7470 MB) Data Comp: Off Server Time: 2026-06-23 04:53:02 UTC
