Speedo died after a persistant tick...
#1041542
02/07/12 03:47 AM
I keep forgetting about this, but my speedometer died the second day I had my latest '90. When I got it, it had a fairly loud tick/whine coming from the cluster. I thought it was a dry cable, and before I could look into it, it stopped working all together. I pulled the cluster and couldn't find any noticeable breaks or damage, cable seemed to move freely. Any suggestions for things I should look at?
Third times a charm.
Re: Speedo died after a persistant tick...
[Re: seely]
#1041543
02/07/12 04:09 AM
[Airplane gaff]"...it stopped working, altogether..."[/Airplane gaff] The speedo drive gear may have stripped on that end of the cable? Could have broken mid-cable somewhere?
[Re: seely]
#1041544
02/07/12 04:18 AM
Do you have a GPS? They all show speed. Mine is dying and I dont want to fix it really. I know its lame but it works. John
SOLD!!: 91 LS 95 SR Rear LSD front 95 LS front brakes Dons Bumper 10k Gorilla/Promark winch Safari Snorkel Dual bouncy 31's
1991 Chevy Suburban 33's. All other stock.
[Re: rxinhed]
#1041545
02/07/12 04:19 AM
Hm, possibly. I should probably see if the cable still rotates with it disco'd from the housing. Is there a drive gear down on the transaxle somewhere? Everything seems solid up top.
[Re: seely]
#1041546
02/07/12 05:01 AM
On the t-case, look for the drive section on the cable.
[Re: rxinhed]
#1041547
02/07/12 04:27 PM
And the other end screw into the speedo itself. I'd undo both and turn one end, while having someone watch the other end. Or, just undo the dash and drive down the street to see it the end it turning.
Funny all the little stuff you are dealing with. The rig must have been generally cared for, but then parked for a lot of time...??? Still, I'd take lesser fixable things for a rde that clean any day.
[Re: MontyMcV]
#1041548
02/07/12 05:16 PM
I remember when messing with mine I hooked the end up at the Tcase to a drill and had someone watch the other end whil I spun it to see if it turn consistently. Mine worked fine just needed some grease.
[Re: RECON45]
#1041549
02/08/12 02:55 PM
Just remembered (I think)... There are little plastc gears in the t-case end. In my 87, the cable had gotten too "sticky" and started to bind. This in turn caused those gears to strip. Had another donor so I pulled some parts from it.
[Re: MontyMcV]
#1041550
02/08/12 08:02 PM
That would make sense. Ugh, WHY did I put off lubing the damn cable? <img src="/forums/images/graemlins/rolleyes.gif" alt="" />
I don't suppose the gear parts are still available? I've called around and there doesn't seem to be any Gen I's in the wrecking yards around here, sadly.
[Re: seely]
#1041551
02/08/12 08:37 PM
Guys isn't that gear the ones you replace to adjust your speedo for different tire sizes? If so, I believe there's a part number in the Specialized Part Number Repository thread. See the FAQ post at the top of the forum for the link. <img src="/forums/images/graemlins/kewl.gif" alt="" />
