Page 3 of 4 1 2 3 4
Re: 95 Fuel Pump Hose Replacment [Re: TheViper] #1041860 02/13/12 07:56 PM
Only one end swivels. Try breaking loose the hard line end.
Same flare nut sizes. Alternate method: with a hack saw or whiz wheel, cut off the crimp on the rubber hose, and peel it off. Cut off the rubber hose with a knife. Both ends have this done. Replace the cut off hose and crumps with FI hose and double clamps. It will hold the pressure just fine.
Re: 95 Fuel Pump Hose Replacment [Re: fasteddy] #1041861 02/13/12 08:04 PM
mxmikie Offline
i soaked the fitting with some brake fluid then i clamped a small set of vice grips on the crimp on the rubber hose side then i could unscrew the swivel from the tank fitting napa has the tools to re-crimp the hose if it tears
Re: 95 Fuel Pump Hose Replacment [Re: TheViper] #1041862 02/13/12 08:17 PM
TheViper Offline OP
alright great information guys...so the 19mm flare nut should spin free from the rubber hose (near metal clamp).
good idea fasteddy..i will def do that if it comes to that
1995 Montero SR
Re: 95 Fuel Pump Hose Replacment [Re: TheViper] #1041863 02/13/12 08:40 PM
Howah Offline
I ended up going underneath the tank and loosen hose from hardline side. use flare nut wrench when possible.
95 Montero SR
Re: 95 Fuel Pump Hose Replacment [Re: Howah] #1041864 02/13/12 09:09 PM
TheViper Offline OP
lol, I actually just did that...that was the end that had the swivel connector. The rubber ends do not swivel.
Last question for everyone...my little rubber hose inside the pump looked good (still gonna replace)...how do you clean the little screen at the end of the pump? It doesnt seem to come off the pump
EDIT: well I finished the project. I ended up just spraying off the screen with a garden hose and just brushing the fuel screen with a tooth brush...everything went back together nicely.
1995 Montero SR
Re: 95 Fuel Pump Hose Replacment [Re: TheViper] #1041865 02/14/12 08:14 AM
Howah Offline
Remove rubber seat from pump
unsnap retaining disk
pull off screen filter
Ops missed edit
95 Montero SR
Re: 95 Fuel Pump Hose Replacment [Re: Howah] #1041866 02/14/12 06:04 PM
TheViper Offline OP
Well this mightve fixed my stutter issue. I was getting a stuttering whenever i ran my gas tank real low, it would last for a couple days in this condition even after i filled up
I ran my gas down real low yesterday and no stutter at all. Its weird bc the small rubber hose looked to be in real good shape and the fuel screen looked fine too?
1995 Montero SR
Re: 95 Fuel Pump Hose Replacment [Re: TheViper] #1041867 02/14/12 06:19 PM
How dirty was the sock on the pump?
Re: 95 Fuel Pump Hose Replacment [Re: fasteddy] #1041868 02/14/12 06:55 PM
TheViper Offline OP
honestly i dont really know...im not sure what a dirty one looks like...to me it didnt look dirty, also im assuming your talking about the fuel screen at the bottom of the pump?
1995 Montero SR
Re: 95 Fuel Pump Hose Replacment [Re: TheViper] #1041869 02/14/12 10:56 PM
Yes, the fuel screen.
Usually, if you can see thru it, it's not the problem. The pump itself often has an internal screen as well on the inlet. Not sure about yours.
In any case, it's fixed. Can't remember, and too lazy to reverse click and look - you did the fuel filter too?
Page 3 of 4 1 2 3 4
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6399 MB (Peak: 0.7318 MB) Data Comp: Off Server Time: 2026-06-17 11:59:02 UTC
