Re: 2.6 ignition timing... what are you running?
[Re: Kevin C]
#1042509
02/25/12 05:03 AM
One tuning trick that may help is to use the dist advance springs from a turbo engine. The primary spring is a bit lighter and allows the timing to come in a bit faster. That can get you better throttle response but keeps your total timing at higher RPMs the same.
I realize every setup is differant... That's what Ive found on my engines.
Ok i do find this interesting, now i have been on rock auto and seen pictures of the starion distributor and cant help but think it looks the exact same as the spare one i grabbed from a 1982 lebaron, do you think the lebaron has the same lighter weights?
1989 Mighty Max 4WD 2.6 Turbo,Auto EFI...megasquirt! 4.62 Rear LSD! 1989 Mighty Max 2WD 2.6 5 speed slammed 1993 Eagle Talon TSI
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5888 MB (Peak: 0.6283 MB) Data Comp: Off Server Time: 2026-06-13 10:45:01 UTCValid HTML 5 and Valid CSS
