I took the Sport out weekend before last and ran into some serious over heating issues. Nothing really at the beginning of the trip, but when I got off road it just went straight to hell. I couldn't figure it out as everything seemed to be fine. Dang thing was even overheating going down hill which it has NEVER done. <img src="/forums/images/graemlins/frown.gif" alt="" />
The only thing I could think of was a fan(s) going south. Since then I'd been getting some abnormal temp behavior so I decided to replace both fans before we take off to Moab next week. I already had a spare assembly so I figured I'd rather be safe than sorry.
So, I spent most of the weekend replacing the fan motors. The spare assembly is an OEM Ford part. The original assembly was from Rock Auto - God only knows where it was made, but it wasn't in the US.
Anyway, I dropped the new motors in, bolted it back to the radiator and then dropped the entire thing back in the truck. Hooked all the wiring back up. Cleaned up a couple things and fired it up. And promptly blew both 25A fan fuses. <img src="/forums/images/graemlins/rolleyes.gif" alt="" /> Checked the docs - the max for the Spal PWM is 30A - and slapped a 30A back in the secondary fan. That worked ok and then I realized that was my last 30A. I went through three 25A fuses with no luck. I called it a night at that point.
I got up the next morning, checked for shorts and found nothing. Figured I could make it to the Autozone without fans since its 6-7 miles but all down hill.
Got to Autozone fine, picked up a bunch of fuses and a 30A breaker for testing. Slapped the breaker in and everything was happy. Been driving it for about 150 miles with no fuse issues.
So far, the cooling seems to be back to "normal". I had to stick it in 2nd for 3-4 miles pushing 4K RPM uphill to get it into the mid 200s. I haven't gotten it to get to 208 to kick in the secondary fan, yet. So, yea, 'normal'.
So, given that I can find NO issues anywhere in the wiring and the fan motors are working just fine, I'm wondering just how well some of these aftermarket OEM-like replacement fan assemblies actually work. I can tell the Ford motors draw more amps. Obviously inrush is significantly higher than my original fan motors. AFAIKT, the Ford motors seems to draw more air.
Anyway, yet one more thing that has to be flipping perfect for this to work without melting down. I hate projects that end 95% perfect. That last 5% just takes all the fun out of the other 95%. <img src="/forums/images/graemlins/frown.gif" alt="" /> With the new exhaust in and the cracked manifold replaced, it runs like a top. Quiet and smooth as glass. Tons of torque - a real joy to drive in the mountains - as long as I don't have to deal with Eisenhower Tunnel or Vail Pass. Zero problems in town driving. Rush hour stop and go in the 90s no problem even with the A/C on.
It would be educational to try this with the factory mechanical fan and shroud just to see if it worked better, worse or the same. However, since that would require some serious work - like moving the engine - I'm going to leave things as they are.
Maybe I'll readdress getting the Montero 3.5L ECM working in the Sport eventually when I have nothing better to break.
Still suck, though, 'cause the 3.5L is absolutely awesome with the 5-speed M/T.
