Re: 31X11.5 Tires? Anybody got a Linky?
[Re: Bubba]
#1046196
05/09/12 05:21 PM
Those are not on the stock 15" rims?
You maybe younger and can run faster, but I am older and have been around long enough to know where all the shortcuts are!
1989 MTs/Dodge Raider SWB V6 5spd - Daily Driver/Work in Progress.....
[Re: Bubba]
#1046197
05/14/12 04:10 AM
Here is from this weekend, They fit well and no rubbing anywhere, the rims are 15x8 steel 8 hole <img src="/forums/images/graemlins/kewl.gif" alt="" /> ![[Linked Image]](http://i64.photobucket.com/albums/h163/hyboosa/IMG_0400.jpg)
2003 limited 20 year anniversary 96 SR 87 Montero SWB=Turbo diesel 4BT T19 4sd with 205 transfer case
[Re: 87monty]
#1046198
05/14/12 04:21 AM
Looks great.Is that lifted? And there 31's correct? I just found a set of 31s here.
1987 Raider,2.6,mt,78"Meyer snow plow,100lb. Doberman alarm,weber carb, lockouts from here- 1989 V-6,SWB, A.T. 4x4, 31'S
[Re: METALMOVER]
#1046199
05/14/12 04:35 AM
Thanks its a fun rig! as for the info there 32's and 2" body lift <img src="/forums/images/graemlins/smile.gif" alt="" />
[Re: 87monty]
#1046200
05/14/12 04:42 AM
Hence the reason you put that in your bio that they were 32's(got confused) well I found a set of 31's no lift so.... <img src="/forums/images/graemlins/cheers.gif" alt="" />
[Re: METALMOVER]
#1046201
05/14/12 05:01 AM
I dont think you would rub much even without a body lift!
[Re: 87monty]
#1046202
05/14/12 05:03 AM
I agree <img src="/forums/images/graemlins/cheers.gif" alt="" />
[Re: 87monty]
#1046203
05/14/12 05:26 AM
33x12.5s, front on 8.5" rims, rear on 10"...both with 4" BS, no rubs: 33x12.5 Muds on 8.5" rims, 4" BS and hauling a trailer: 32x11.5s on 8.5" with 3.75" BS: I post these images often, having used my Raider as a test bed for many wheel and tire combinations.
