Bump Stops?? #1046766 05/17/12 07:17 PM
Bubba Offline OP
Anybody got any Bumpstops or a part # for a set of Bumpstops for a SWB 89 V6??
89 V6 SWB
OEM Sunroof
RPW Headers & Custom Exhaust
15" Toyota 4Runner Chrome Rims
33X12.5 Goodyear Wrangler Duratrac
Stainless Steel Lugs
85 2.6 Montero (RIP) <img src="/forums/images/graemlins/frown.gif" alt="" />
Re: Bump Stops?? [Re: Bubba] #1046767 05/17/12 08:08 PM
FWIW, those are the rear bump stops (there are front ones also).
I don't have the p/n but you may want to doublecheck the part number repository thread (see FAQ post) or download the Mitsubishi ASA app to figure out the correct part number. It's a pretty simple and straight forward app but you do need your VIN number or a VIN number of a similar vehicle.
<img src="/forums/images/graemlins/cyclops.gif" alt="" />
Re: Bump Stops?? [Re: off-roader] #1046768 05/17/12 10:56 PM
heathdogg Offline
Now I know what your talking about. I used some of a jeep for my LWB. They might work. The mounting holes are a smidge off so you gotta make the holes about 1/8" bigger. Check the hieght to see if they will work.
Blacktero: 90 Montero Lwb V6 RS Model. 16" Toyota Alloy Rims, Dual Bouncy's; Gen II Front Rotors & Calipers; Rear LSD
Sraider: 87 Raider 2.6 base. Work yet to be done.
Re: Bump Stops?? [Re: heathdogg] #1046769 05/17/12 11:47 PM
Bubba Offline OP
Is there a NAPA part (part#) thats available??
89 V6 SWB
OEM Sunroof
Re: Bump Stops?? [Re: Bubba] #1046770 05/18/12 12:51 AM
KrzyDav Offline
I take it your are broken off and totally gone????
Mine (as you can see in that photo) are original and don't even have ozone cracks in them. Maybe cause my truck has lived without salt for 3/4 of it's years. They are a pretty hard rubber,,,and as I've said before Gen one rubber suspention and other rubber parts seem far superior than other auto makers(BMW comes to mind) and I alway try to get OEM rubber parts.
dave h.
Re: Bump Stops?? [Re: KrzyDav] #1046771 05/18/12 02:23 AM
KrzyDav Offline
MB584148
$18.69
Stopper,RR Susp spring
(same part for left side)
I got part number cast on side of my bump stops. MB631470.
That number has been superceded with the new number above. I recon they must use this on other models as it is avaiable at .com (Korum Mitsu, WA.) for net sources there's also the one in TX and the one in Maryland just reopened. At one time there was one in Longbeach,CA. Chose you poison.
dave h.
Re: Bump Stops?? [Re: KrzyDav] #1046772 05/23/12 07:08 AM
KrzyDav Offline
Bubba, you out there?
dave h.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6179 MB (Peak: 0.7097 MB) Data Comp: Off Server Time: 2026-06-06 23:38:00 UTC
