The A/C compressor on my 95 LS (3.0) has started clattering--- #1047082 05/23/12 11:35 PM
9
95LS Offline OP
I noticed a week or so ago, that when I stepped out of my truck with the engine running, I could hear a distinct clatter coming from the area of the A/C compressor. I turned of the A/C,.......and sure enough, the clatter stopped as well, compressor back on, and the clatter began again. I have 240,000 miles on the truck, (runs great) and the A/C is icecold. Its still the original compressor,....hate to tear it apart with it still cooling, but, on the other hand, I dont want the compressor to disintegrate and fill the system with debris.
Any thoughts on this?
Brian in Austin
95 3.0 LS (24v)
241,000 miles and still going
Re: The A/C compressor on my 95 LS (3.0) has started clattering--- [Re: 95LS] #1047083 05/24/12 11:51 AM
P
pcc Offline
If the system has been leaking and you've just been topping it up without adding oil then maybe it just needs oil.
Re: The A/C compressor on my 95 LS (3.0) has started clattering--- [Re: pcc] #1047084 05/24/12 01:41 PM
9
95LS Offline OP
No, I have never needed to top it up.
95 3.0 LS (24v)
Re: The A/C compressor on my 95 LS (3.0) has started clattering--- [Re: 95LS] #1047085 05/24/12 06:19 PM
Try adding some oil, then.
Re: The A/C compressor on my 95 LS (3.0) has started clattering--- [Re: JohnnyBfromPeoria] #1047086 05/24/12 07:15 PM
9
95LS Offline OP
Is it possible to be low on oil on a system that has never been opened and has always functioned fine (and, other than the clatter, still is)
How do I add oil to a sealed operating system,....and,...how much would I add?
Brian
95 3.0 LS (24v)
Re: The A/C compressor on my 95 LS (3.0) has started clattering--- [Re: 95LS] #1047087 05/24/12 09:51 PM
P
pcc Offline
There are injection tools (I have one) that would keep the system sealed, otherwise you'd have to evacuate, add just oil and recharge, or oil with refrigerant. Adding oil to a system that has remained closed is a guessing game on how much to add. Too much, as you may know, will reduce the efficiency.
Maybe the shaft bearing/sleeve is worn?? Try removing the drive belt and pull/push/shack the pulley to see if it has excessive play. You may need to lock the clutch with 12v jumper.
Here's a site where parts may be available:
http://www.acsource.com/index.aspx
I've dealt with them and they are very reputable.
Re: The A/C compressor on my 95 LS (3.0) has started clattering--- [Re: pcc] #1047088 05/25/12 12:26 AM
The belt pulley has a bearing seperate from the compressor internal bearings, which may rattle only under load/clutch engaged...
Re: The A/C compressor on my 95 LS (3.0) has started clattering--- [Re: fasteddy] #1047089 05/25/12 06:26 AM
9
95LS Offline OP
Are you referring to the tensioner pulley or the pulley on the front of the compressor?
95 3.0 LS (24v)
Re: The A/C compressor on my 95 LS (3.0) has started clattering--- [Re: 95LS] #1047090 05/25/12 06:09 PM
On the compressor. IIRC, the pulley has it's own bearing, independent of the compressor shaft bearing. I've had them go bad in the past. You can generally hear it with a mechanics stethoscope, a lighter rattle than with the compressor engaged..
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6281 MB (Peak: 0.7316 MB) Data Comp: Off Server Time: 2026-06-23 20:03:12 UTC
