Rating: 5
Page 5 of 15 1 2 3 4 5 6 7 14 15
Re: 4Cyl turbo Vs V6 3.0? [Re: PHIL_] #1047169 06/20/12 03:07 PM
87monty Offline OP
I need to do my Evo's timing belts as soon as I send my students home for the summer... I too fretted over the balancer belt, but I also like how the engine works with it in there, so I bought Kevlar timing and balance belts from Gates. Might be something for you to check into too?
I like the sound of Kevlar, I will look around for them thanks <img src="/forums/images/graemlins/smile.gif" alt="" />
2003 limited 20 year anniversary
96 SR
87 Montero SWB=Turbo diesel 4BT
T19 4sd with 205 transfer case
Re: 4Cyl turbo Vs V6 3.0? [Re: 87monty] #1047170 06/23/12 04:26 AM
87monty Offline OP
So they dont make kevlar timing belts for the 4G64 so im going to take the shafts out <img src="/forums/images/graemlins/cyclops.gif" alt="" />. I have not had problems with my starion motor at all with the shafts out and I have gone everywhere in it. I have found the right 16V pistons as well, I will report as soon as they are in my hands>
96 SR
Re: 4Cyl turbo Vs V6 3.0? [Re: 87monty] #1047171 11/02/12 02:11 AM
87monty Offline OP
So I have a fresh board (20 over)2.4 decked Block with oil squirters machined in as well. just came out of the shop. So the Build continues......
I picked up some goodies on the way like a evo 8 turbo <img src="/forums/images/graemlins/smile.gif" alt="" />
Re: 4Cyl turbo Vs V6 3.0? [Re: 87monty] #1047172 11/03/12 11:00 PM
87monty Offline OP
Here is the Dohc 16V 4G64 2G pistons on forged 1G rods:)
The pistons were kinda hard to find, but after you know what to look fot it helps. If anyone heeds help with this build I can show you where to look for the most part <img src="/forums/images/graemlins/kewl.gif" alt="" />
96 SR
Re: 4Cyl turbo Vs V6 3.0? [Re: 87monty] #1047173 11/07/12 04:28 AM
87monty Offline OP
Here is the set up( No internals) I had to extend the header a 1-1/4 to get the clearance I needed for this turbo set up.
96 SR
Re: 4Cyl turbo Vs V6 3.0? [Re: 87monty] #1047174 11/07/12 05:00 AM
Kevin C Offline
Looks nice! I'm getting closer to being able to work on my Raider. I just need to finish my new shop.
Re: 4Cyl turbo Vs V6 3.0? [Re: Kevin C] #1047175 11/07/12 05:41 AM
87monty Offline OP
Thanks Kevin! I was wondering how it was going to all pan out, but if theres a will theres a way! This will be the best combo yet. I have the 91 lock up tranny and front Lsd waiting for its new home as well. Woo HOo <img src="/forums/images/graemlins/notooth.gif" alt="" />
96 SR
Re: 4Cyl turbo Vs V6 3.0? [Re: 87monty] #1047176 11/07/12 06:45 PM
Are you doing the coolant reroute to the front of the head and blocking off the rear outlet? I hear the old bypass tube can be cut to fit. I also read you have to angle the tube up to clear the waterpump...
Re: 4Cyl turbo Vs V6 3.0? [Re: fasteddy] #1047177 11/07/12 07:46 PM
87monty Offline OP
Yeah I found a few ideas for the water system that looked good and should work. I would like to stay as far away from the turbo/header as possable. That might be the only tricky part
96 SR
Re: 4Cyl turbo Vs V6 3.0? [Re: 87monty] #1047178 11/07/12 08:52 PM
Wow, I always wanted to do this swap in a montero. I did the 8v 2.4 swap on my old '94 and i loved it once i got all the bugs worked out. Turbo's rock!
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.005s) Memory: 0.6601 MB (Peak: 0.7660 MB) Data Comp: Off Server Time: 2026-05-29 23:54:45 UTC
