Rating: 5
Page 7 of 15 1 2 5 6 7 8 9 14 15
Re: 4Cyl turbo Vs V6 3.0? [Re: Kevin C] #1047189 11/10/12 08:23 PM
87monty Offline OP
Jason, Looks like a good setup.
Good to see you you posting about projects.
Kevin
Hi Kevin! Oh man this project is coming together nice.
I should be making some good power at low rpm's for sure.
2003 limited 20 year anniversary
96 SR
87 Montero SWB=Turbo diesel 4BT
T19 4sd with 205 transfer case
Re: 4Cyl turbo Vs V6 3.0? [Re: 87monty] #1047190 12/30/12 03:45 AM
87monty Offline OP
So I have made some progress, I have the power steering and alternator in place. The turbo is a Bullseye 57 Trim with stock dsm manifold. was going to run the evo 8 but changed my mind. Cant wait!!
96 SR
Re: 4Cyl turbo Vs V6 3.0? [Re: 87monty] #1047191 12/30/12 04:57 AM
What is the timing belt routing like?
Re: 4Cyl turbo Vs V6 3.0? [Re: rxinhed] #1047192 12/30/12 08:22 AM
87monty Offline OP
Hi Russ! here is a picture of a set up mine will look like.
96 SR
Re: 4Cyl turbo Vs V6 3.0? [Re: 87monty] #1047193 12/30/12 09:20 AM
By the looks of your engine, you've installed a BSE kit, too?
Sweet purple cam sprockets, batman! <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: 4Cyl turbo Vs V6 3.0? [Re: rxinhed] #1047194 12/30/12 06:48 PM
87monty Offline OP
Yeah did the BSE kit, Not going to have the fancy purple cam gears like that guy, just good ol stock mitsu. you do have to run the 2.4 belt due to the higher deck height as well. going to pull the starion motor/tranny out in a few weeks to make room for the beast. <img src="/forums/images/graemlins/smile.gif" alt="" />
96 SR
Re: 4Cyl turbo Vs V6 3.0? [Re: 87monty] #1047195 12/30/12 08:05 PM
You'll be sorry...
Re: 4Cyl turbo Vs V6 3.0? [Re: fasteddy] #1047196 12/30/12 09:30 PM
87monty Offline OP
My good friend builds some of the coolest and powerful dsm motors iv ever seen and all have BSE's kits.
NO real vibration from idle to 9 grand. The only way you will notice is with solid mounts, which is silly unless your racing. If you loose a bs belt you could blow your motor. What happens is the BS belt wedges into the main timing belt). Also Bent valves on a new head, that my friend would be devastating.
This 2.4 build is not cheep at all.. and if (any) vibration that may occur is worth it. <img src="/forums/images/graemlins/smile.gif" alt="" />
Re: 4Cyl turbo Vs V6 3.0? [Re: 87monty] #1047197 02/15/13 11:32 PM
87monty Offline OP
IM back with some good updates. New mild ported head is on,
Figured out a good turbo and exhaust manifold option. shes looking good! Just need a few little goodies and adjust the timming belt and shes going in.
96 SR
Re: 4Cyl turbo Vs V6 3.0? [Re: 87monty] #1047198 02/16/13 01:29 AM
lordtrunks Offline
why did you reconfigure the alternator and power steering?
89 2 dr turbo diesel
89/88 "Backwoods sas"
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6606 MB (Peak: 0.7663 MB) Data Comp: Off Server Time: 2026-05-29 19:54:35 UTC
