Re: 4Cyl turbo Vs V6 3.0?
[Re: Kevin C]
#1047189
11/10/12 08:23 PM
Jason, Looks like a good setup.
Good to see you you posting about projects.
Kevin Hi Kevin! Oh man this project is coming together nice. I should be making some good power at low rpm's for sure.
2003 limited 20 year anniversary 96 SR 87 Montero SWB=Turbo diesel 4BT T19 4sd with 205 transfer case
[Re: 87monty]
#1047190
12/30/12 03:45 AM
So I have made some progress, I have the power steering and alternator in place. The turbo is a Bullseye 57 Trim with stock dsm manifold. was going to run the evo 8 but changed my mind. Cant wait!! ![[Linked Image]](http://i64.photobucket.com/albums/h163/hyboosa/IMG_0015.jpg)
[Re: 87monty]
#1047191
12/30/12 04:57 AM
What is the timing belt routing like?
[Re: rxinhed]
#1047192
12/30/12 08:22 AM
What is the timing belt routing like? Hi Russ! here is a picture of a set up mine will look like. ![[Linked Image]](http://i64.photobucket.com/albums/h163/hyboosa/000009102.jpg)
[Re: 87monty]
#1047193
12/30/12 09:20 AM
By the looks of your engine, you've installed a BSE kit, too?
Sweet purple cam sprockets, batman! <img src="/forums/images/graemlins/kewl.gif" alt="" />
[Re: rxinhed]
#1047194
12/30/12 06:48 PM
Sweet purple cam sprockets, batman! <img src="/forums/images/graemlins/kewl.gif" alt="" /> Yeah did the BSE kit, Not going to have the fancy purple cam gears like that guy, just good ol stock mitsu. you do have to run the 2.4 belt due to the higher deck height as well. going to pull the starion motor/tranny out in a few weeks to make room for the beast. <img src="/forums/images/graemlins/smile.gif" alt="" />
[Re: 87monty]
#1047195
12/30/12 08:05 PM
[Re: fasteddy]
#1047196
12/30/12 09:30 PM
My good friend builds some of the coolest and powerful dsm motors iv ever seen and all have BSE's kits. NO real vibration from idle to 9 grand. The only way you will notice is with solid mounts, which is silly unless your racing. If you loose a bs belt you could blow your motor. What happens is the BS belt wedges into the main timing belt). Also Bent valves on a new head, that my friend would be devastating. This 2.4 build is not cheep at all.. and if (any) vibration that may occur is worth it. <img src="/forums/images/graemlins/smile.gif" alt="" />
[Re: 87monty]
#1047197
02/15/13 11:32 PM
IM back with some good updates. New mild ported head is on, Figured out a good turbo and exhaust manifold option. shes looking good! Just need a few little goodies and adjust the timming belt and shes going in. ![[Linked Image]](http://i64.photobucket.com/albums/h163/hyboosa/IMG_1612_zps37d4c29d.jpg) ![[Linked Image]](http://i64.photobucket.com/albums/h163/hyboosa/IMG_1610_zpsfd940cff.jpg)
[Re: 87monty]
#1047198
02/16/13 01:29 AM
why did you reconfigure the alternator and power steering?
89 2 dr turbo diesel 89/88 "Backwoods sas"
