Rating: 5
Page 10 of 15 1 2 8 9 10 11 12 14 15
Re: 4Cyl turbo Vs V6 3.0? [Re: 87monty] #1047219 02/24/13 08:29 PM
87monty Offline OP
Here is the water pump mod. I machined a press fit tube and used honda-bond to seal it inside and out.
[IMG]
2003 limited 20 year anniversary
96 SR
87 Montero SWB=Turbo diesel 4BT
T19 4sd with 205 transfer case
Re: 4Cyl turbo Vs V6 3.0? [Re: 87monty] #1047220 02/24/13 11:49 PM
Are you worried about turbo heat affecting the hose?
Re: 4Cyl turbo Vs V6 3.0? [Re: rxinhed] #1047221 02/25/13 02:29 AM
87monty Offline OP
I think im going to do a heat deflector, they make some cool flexable stuff. you can bend and shape any way you like.
Think it comes in square sheets in diffrent sizes. But yes there will be a lot of heat in this area for sure. Im pretty far away but want to be safe for sure. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Found this stuff http://www.jegs.com/i/Turbonetics/880/20...CFU1yQgodYnUAZQ
96 SR
Re: 4Cyl turbo Vs V6 3.0? [Re: JohnnyBfromPeoria] #1047222 03/14/13 12:59 AM
87monty Offline OP
A 2.4 fits in an '87 Raider/Montero as is. You only need to whack the oil pan a few times/places to "clearance" it.
Hi there John, So im at the end of the build and getting ready to seal up the 2.4 truck pan. From what you say there is little clearance issue to deal with on the pan and front diff? I will have the v6 diff with lsd going in around the same time. Its a lot easer to make any mods now while shes out of the rig for sure. If its a few whacks then im sealing it up and will deal with it when installed.
96 SR
Re: 4Cyl turbo Vs V6 3.0? [Re: 87monty] #1047223 03/14/13 01:37 AM
87monty Offline OP
So I have found a really good cooling Idea, first make one of these on the back of the head.
Then go to any parts store and ask for a 1985 Bmw 318i thremostat part#3578 (at autozone), they are 30$ and this is what it looks like.Good thing is you can mount it any place. you can cap off one in if your not using the heater (I am) and your good to go.
96 SR
Re: 4Cyl turbo Vs V6 3.0? [Re: 87monty] #1047224 03/18/13 04:12 PM
MainstreaM Offline
In hose thermostat! I did this with my Jeep Liberty Diesel. It is holding up well with about 13k miles on it.
http://www.lostjeeps.com/forum/phpBB3/viewtopic.php?f=5&t=63587
Kane
89 Conquest - 2.4 DOHC <--Thats right DOHC Turbo and MPI.
87 Starion flatsider - under restoration
87 Conquest - Saved from the crusher
86 Conquest - Another crusher rescue
88 Conquest - Previous owner abandoned project
87 Raider - under construction
86 Conquest - DD
Re: 4Cyl turbo Vs V6 3.0? [Re: MainstreaM] #1047225 03/18/13 10:02 PM
87monty Offline OP
Kane
Yep I agree, My buddy has on on his turbo set up and works great. All I can say is where there's a will there's a way!
96 SR
Re: 4Cyl turbo Vs V6 3.0? [Re: 87monty] #1047226 03/19/13 09:58 PM
ryany Offline
I'm not sure how you're plumbing your cooling system, but if your remotely mounted thermostat doesn't have a small amount of coolant flowing past it, it could remain closed well past the point of engine overheating. Without some coolant circulation, it won't be getting the hot engine coolant near enough to it to open when it should be opening.
Hopefully you've already planned for this...
95 Montero SR
Re: 4Cyl turbo Vs V6 3.0? [Re: ryany] #1047227 03/21/13 08:03 PM
87monty Offline OP
Hi ryany,
These motors have cross flow cooling, my new thremostat will be only 6 inchs from the original location. There is a small weep hole in the thermostat and will have water pressure pushing on it tell its at the correct temp to open.
From my research a lot of people are using this due to tight spaces in the set up.
96 SR
Re: 4Cyl turbo Vs V6 3.0? [Re: 87monty] #1047228 04/20/13 07:10 PM
87monty Offline OP
Some new pics of my external wastegate& down pipe.
Stainless tube mod needed to route exhaust back in down pipe.
Had to cut and re position the down pipe to clear firewall.
96 SR
PHP: 7.4.33 Page Time: 0.009s Queries: 16 (0.006s) Memory: 0.6598 MB (Peak: 0.7842 MB) Data Comp: Off Server Time: 2026-06-10 00:37:11 UTC
