Rating: 5
Page 14 of 15 1 2 12 13 14 15
Re: 4Cyl turbo Vs V6 3.0? [Re: 87monty] #1047259 12/24/14 07:43 AM
Kevin C Offline
Looking great!!! I think I'm having valve envy. smile I'm curious how that setup would work with my lockup auto. You just never know. <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: 4Cyl turbo Vs V6 3.0? [Re: Kevin C] #1047260 12/24/14 04:38 PM
I liked the non lockup 4cyl auto with a turbo better than the non lockup V6 auto trans with a turbo, I think a lockup 4cyl auto would be the man. The smaller torque converter gets the turbo spooling quicker which i liked for my mostly around town driving.
Re: 4Cyl turbo Vs V6 3.0? [Re: TOASTY] #1047261 12/24/14 06:36 PM
Kevin C Offline
I agree that a little bit of stall speed is a good thing. My lockup converter is from a V6. I did send it in an have the fins modded to get a higher stall. Combined with the small turbo from the stock starion engine, it spools very well. A decent down pipe off the turbo also made a huge difference.
From what I have read, the stock 2.0 turbo on a 2.4 spools pretty quickly.
I have been fooling with 2.6 motors for a long long time, it works, but at the same time it getting a bit boring. That the the valve cover on the 2.4 motor is way, way cooler looking than the the 2.6's.
Re: 4Cyl turbo Vs V6 3.0? [Re: TOASTY] #1047262 12/24/14 07:18 PM
87monty Offline OP
Thanks guys! I am really happy how things are coming out.
I did find a dual runner cyclone intake complete set up im going with. My fellow dsm guys said it gains 30-50ft-lbs on the bottom end <img src="/forums/images/graemlins/kewl.gif" alt="" />
2003 limited 20 year anniversary
96 SR
87 Montero SWB=Turbo diesel 4BT
T19 4sd with 205 transfer case
Re: 4Cyl turbo Vs V6 3.0? [Re: 87monty] #1047263 01/02/15 05:10 AM
87monty Offline OP
So I have test fit the turbo with the new FP exhaust manifold, wow im very impressed with there build quality.
Forced performance makes good Sh*t but can be expensive.
I am waiting on my cyclone dual runner intake which should be here next week.
96 SR
Re: 4Cyl turbo Vs V6 3.0? [Re: 87monty] #1047264 01/03/15 12:58 AM
lordtrunks Offline
Looking good I think you should run a real air box and not rock the open filter i think your looking for trouble leaving the filter out in the open like that. the gen 1 V6 air box is a good fit.
89 2 dr turbo diesel
89/88 "Backwoods sas"
Re: 4Cyl turbo Vs V6 3.0? [Re: lordtrunks] #1047265 01/03/15 01:35 AM
87monty Offline OP
You are on to something,I want build a aluminum sheet metal cold air unit.I might end up doing a snorkel like some of you guys do. Last thing I want is to suck up hot engine heat from under the hood. I will look at the v6 housing and see if I can save myself some building time.
Thanks for the idea <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: 4Cyl turbo Vs V6 3.0? [Re: 87monty] #1047266 01/03/15 01:58 AM
I have some Starion A/F assembles if you'd like one.
Re: 4Cyl turbo Vs V6 3.0? [Re: rxinhed] #1047267 01/03/15 07:12 PM
87monty Offline OP
Thanks Russ, I will way my options and see what would fit best. I want to upgrade my battery capacity so that's a factor too.
96 SR
Re: 4Cyl turbo Vs V6 3.0? [Re: 87monty] #1047268 01/04/15 09:50 PM
Group 27 fits on the OE battery tray in that position. Otherwise, could relocate to front left behind headlight, there's already a divot for that position.
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.006s) Memory: 0.6559 MB (Peak: 0.7625 MB) Data Comp: Off Server Time: 2026-07-10 21:25:25 UTC
