Rating: 5
Page 15 of 15 1 2 13 14 15
Re: 4Cyl turbo Vs V6 3.0? [Re: rxinhed] #1047269 01/05/15 02:09 AM
87monty Offline OP
Group 27 fits on the OE battery tray in that position. Otherwise, could relocate to front left behind headlight, there's already a divot for that position.
Thanks Russ, I will look into the group 27. Is it much bigger than stock do you know? I would love dual optima or odyssey battery's but wow that's like 400$ right there!
Maybe I can do one at a time
<img src="/forums/images/graemlins/zombie.gif" alt="" />
2003 limited 20 year anniversary
96 SR
87 Montero SWB=Turbo diesel 4BT
T19 4sd with 205 transfer case
Re: 4Cyl turbo Vs V6 3.0? [Re: 87monty] #1047270 01/30/15 11:28 PM
87monty Offline OP
Test fitting top aluminum water line. This [censored] was thick and bent really nice in the tube bender. Will need to trim a little off at the radiator side and make a few hold down brackets but that's pretty much it.
96 SR
Re: 4Cyl turbo Vs V6 3.0? [Re: 87monty] #1047271 01/31/15 06:06 AM
zarktheshark Offline
How do the heater core lines run?
'88 Raider. 2.6L dead...2.4L swap in progress, AT, 33's, 2 bouncy seat,AC, CC, 2.25 exh, 2" Tbar, 2" BL, rear DB, rear LSD,4.90's, SW hubs,gen2 uca's, KYB shocks, snorkel, elec fan, MSD.
'99 chev k3500 crewcab
'15 Subaru XV
'03 BMW i325
Re: 4Cyl turbo Vs V6 3.0? [Re: zarktheshark] #1047272 02/01/15 01:27 AM
87monty Offline OP
Going to use one of the original locations on the thermostat for one side. Then weld in a bung on the water pump exit tube I machined. Should work out good. Not sure he same guy on FB but I pasted this here too <img src="/forums/images/graemlins/smile.gif" alt="" />
96 SR
PHP: 7.4.33 Page Time: 0.010s Queries: 15 (0.007s) Memory: 0.6166 MB (Peak: 0.6768 MB) Data Comp: Off Server Time: 2026-07-10 19:20:19 UTC
