88 5 speed mighty max 3rd and 4th gear not working #1047674 06/04/12 07:11 AM
dsmguy Offline OP
today i was driving and shifted into 3rd and 4th gear and it was as if i was putting it into nuetral. i still have 1st 2nd and reverse. i have tried to put into 4wd and go into 3rd and 4th but still will not work. any ideas of what could of happen. the tranny is not griding and all other gears shift smooth
89 Raider V6 5 speed factory lsd rear
88 mighty max 4 cyl. 5 speed
Re: 88 5 speed mighty max 3rd and 4th gear not working [Re: dsmguy] #1047675 06/04/12 01:37 PM
cheesegrater Offline
Broken shifter fork?
Re: 88 5 speed mighty max 3rd and 4th gear not working [Re: cheesegrater] #1047676 06/04/12 04:01 PM
Usually you loose all but 3rd, we've never had any luck with those KM145's. My suggestion as always is remove the Chrysler trans and swap in the Aisin auto <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: 88 5 speed mighty max 3rd and 4th gear not working [Re: TOASTY] #1047677 06/04/12 04:30 PM
harleydude446 Offline
if you decide not to fix the truck I would be willing to buy the two front skid plates from you if you want to sell them <img src="/forums/images/graemlins/patriot.gif" alt="" />
Re: 88 5 speed mighty max 3rd and 4th gear not working [Re: harleydude446] #1047678 06/04/12 05:59 PM
When mine failed, I lost all but 4th. I'd pull the shifter and see what moving the shift rails by hand does. May have lost the 3-4 shift fork connection to the rail. This would mean that you can not lock 3rd or 4th to the shaft to engage those gears. Since 1 and 2 engage, I don't think you have the classic bad input shaft the km145 is known for, but it's possible...
Re: 88 5 speed mighty max 3rd and 4th gear not working [Re: fasteddy] #1047679 06/04/12 10:11 PM
dsmguy Offline OP
I pulled of the shifter and shifted the rails by hand and put it into 3-4 gear.i can see all the shift rods moving and working. i am guessing it is the shift fork that possibly broke or maybe a roll pin. is there any info on how to rebuild this transmission or is there a stronger tranny out there? will the v6 montero tranny fit into the 4cyl mighty max?
Re: 88 5 speed mighty max 3rd and 4th gear not working [Re: harleydude446] #1047680 06/04/12 10:12 PM
dsmguy Offline OP
sorry my truck did not come with them. i am looking for a set also.
Re: 88 5 speed mighty max 3rd and 4th gear not working [Re: dsmguy] #1047681 06/04/12 10:23 PM
v6 5psd will not fit. You're stuck with the km145.
I think it's:
shift fork spring pin came out or broke
3-4 syncro failed
Try pulling the tranny bottom pan and see if there are any bits in there. Drain tranny juice over a magnet to look for fines. Move the shifter and see if the 3-4 shift fork moves.
Re: 88 5 speed mighty max 3rd and 4th gear not working [Re: fasteddy] #1047682 06/04/12 10:33 PM
dsmguy Offline OP
thanks. i will drop pan today. i hope its just a bolt and not synchros. i could not find info in the archives on how to rebuild or tear down the tranny. any advice on were to look?
Re: 88 5 speed mighty max 3rd and 4th gear not working [Re: dsmguy] #1047683 06/04/12 11:21 PM
89 montero fsm on mitsubishilinks.com (iirc).
The spring pin is accessible from the bottom pan, and can be repaired in the truck. If it's the syncro pair, you have to tear down the tranny. It's not real hard, but you may need some special tools. I managed with normal hand tools to rebuild a similar tranny (mazda R in a Navaho).
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.004s) Memory: 0.6383 MB (Peak: 0.7614 MB) Data Comp: Off Server Time: 2026-06-10 04:06:27 UTC
