Spark Plugs and Wires for 95 SR
#1048405
06/23/12 04:04 PM
So im thinking im gonna change out the spark plugs and wires on my montero. I have a good friend who is gonna help me with it as im not very mechanically inclined. After researching on here ive decided to go with NGK plugs and wires.
I was hoping someone can just confirm that ive chosen the right plugs and wires for my 95 montero
NGK (5464) BKR5EIX-11 Iridium IX NGK 8692 wires
Thanks
1995 Montero SR
Re: Spark Plugs and Wires for 95 SR
[Re: TheViper]
#1048406
06/23/12 05:10 PM
PFR6J11 plugs per the FSM. This may be an obsolete number, so check it.
edit: You have the correct numbers per the NGK catalog...
[Re: TheViper]
#1048407
06/24/12 02:19 AM
I purchased these from
OEM spark plugs MS851335 OEM wire set MD311208
Good luck.
<a href="Mitsubishi online" target="_blank">http://www.oemmitsubishiparts.com/parts/...amp;searchText=</a>
1994 Montero SR 3.5 DOHC, Safari Snorkel, Diehard Platinum, OME suspension, factory rear locker, rear sway bar removed, Cobra 75 WX ST, 33" BFG KM2 New Mexico Land of Enchantment
[Re: matseel]
#1048408
06/24/12 07:05 PM
Good luck.
<a href="Mitsubishi online" target="_blank">http://www.oemmitsubishiparts.com/parts/...amp;searchText=</a> thanks for the input, but i think ill pass on $14/plug and $75 wires. So i do have the correct parts listed?
1995 Montero SR
[Re: TheViper]
#1048409
06/25/12 04:49 AM
I installed the same spark plugs on my Montero 96 SR (NGK Iridium IX Spark Plugs BKR5EIX-11 # 5464).
[Re: Monster]
#1048410
06/25/12 05:32 AM
I installed the same spark plugs on my Montero 96 SR (NGK Iridium IX Spark Plugs BKR5EIX-11 # 5464). thanks for the confirmation...how did the monty run after u put those new plugs in? could u notice a difference
1995 Montero SR
[Re: TheViper]
#1048411
06/25/12 06:37 PM
I installed the same spark plugs on my Montero 96 SR (NGK Iridium IX Spark Plugs BKR5EIX-11 # 5464). thanks for the confirmation...how did the monty run after u put those new plugs in? could u notice a difference It had a bad cylinder before the engine rebuild with the old spark plugs (they were NGKs too) but it runs very smooth now, no lack in power whatsoever. <img src="/forums/images/graemlins/kewl.gif" alt="" /> I am sure the last thing I would have to worry about in my engine (after installing those iridiums) would be spark plugs.
[Re: Monster]
#1048412
06/26/12 12:01 AM
You spell that "iridium$$$$$$", but they are worth it. I got 137k out of a set on the wife's Subie 3.0 boxer6, and only changed them when the guilt got too bad - really didn't need to.
[Re: fasteddy]
#1048413
06/26/12 02:20 AM
You spell that "iridium$$$$$$", but they are worth it. I got 137k out of a set on the wife's Subie 3.0 boxer6, and only changed them when the guilt got too bad - really didn't need to. They r really not 2 bad as far as $$$$ goes, I got 6 of them for just under $40 and free shipping. Thats shocking that those lasted you so long, thats crazy!
1995 Montero SR
[Re: TheViper]
#1048414
06/26/12 05:44 AM
I found the exact OEM spark plugs for $12.47 on amazon.com Denso The stealer is $10.40. FYI Believe it or not some of the belts were cheaper from stealer than Napa. Just a thought
