Re: Spark Plugs and Wires for 95 SR
[Re: off-roader]
#1048435
07/23/12 04:05 AM
Please reduce the size of your pictures. <img src="/forums/images/graemlins/kewl.gif" alt="" /> Sorry bout that Ray, fixed
1995 Montero SR
[Re: TheViper]
#1048436
07/23/12 04:27 AM
No problem and thanks for taking care of it. Btw,if you use the code marked 'IMG Code for Forums & Message Boards' instead of what you used, you can simply add it directly to your post and it will show ths smaller pic automatically in the post. <img src="/forums/images/graemlins/kewl.gif" alt="" />
[Re: off-roader]
#1048437
07/23/12 05:04 AM
No problem and thanks for taking care of it. Btw,if you use the code marked 'IMG Code for Forums & Message Boards' instead of what you used, you can simply add it directly to your post and it will show ths smaller pic automatically in the post. <img src="/forums/images/graemlins/kewl.gif" alt="" /> lol, thats actually how i initially did it, i did use the "IMG Code for Forums & Message Boards" from tinypic <img src="/forums/images/graemlins/frown.gif" alt="" />
1995 Montero SR
[Re: TheViper]
#1048438
07/23/12 09:45 PM
Quick question regarding changing the plugs...how cooled down does the engine need to be to safely change the spark plugs?
Does it have to be stone cold, or is sitting for like 4hrs good enough?
1995 Montero SR
[Re: TheViper]
#1048439
07/23/12 11:37 PM
A little warm is better. The plug won't be as tight in the threads and you have less chance of galling them.
[Re: fasteddy]
#1048440
07/23/12 11:39 PM
A little warm is better. The plug won't be as tight in the threads and you have less chance of galling them. fantastic, thanks for the info! I got my hood up now, in the end it should be about a 4hr cool down time, hopefully thats good enough...i just cant wait till the weekend
1995 Montero SR
[Re: TheViper]
#1048441
07/24/12 03:39 AM
So i did get the other plugs finally changed on the driver side. Cylinder 4 and 6 spark plugs were covered in oil <img src="/forums/images/graemlins/frown.gif" alt="" />
whats the significance of this, i know it cant be good?
EDIT: the good thing about the plugs being covered in oil is that the electrode part was completely dry
1995 Montero SR
