got another one.... #1048633 06/30/12 09:11 PM
4x4troy Offline OP
i like my 2000 4x4 5 spd so much i went and got another one...well this one is a 95 4x4 auto. has cold ac and drives good and stole it for $600. will post some pics later
1995 Kia sportage 4x4 2.0 dohc auto...Mine
2000 kia sportage 4x4 2.0 dohc 5spd...Melissa's
2002 Kia sportage 2wd 2.0 doch 5 spd...parts truck
Re: got another one.... [Re: 4x4troy] #1048634 06/30/12 11:39 PM
4x4troy Offline OP
Re: got another one.... [Re: 4x4troy] #1048635 07/31/12 06:04 PM
4x4troy Offline OP
just converted the abs system to std brakes on my 95. swapping out rear axles to go from 26 spline to 28 spline and bigger rear brakes
Re: got another one.... [Re: 4x4troy] #1048636 08/02/12 02:22 PM
4
4runnernomore Offline
Straight swap? Photos please
97 Sporty, snorkel, K&N filter,chipped, ext forks, 40mm Dob Springs, KYB struts, 35mm Jeep TJ Springs, RAV 4 OME shocks, Kaiser Locker 5.38 R&P's, 1&3/8 body lift, 245/75 R16 D674's Sports steering wheel, bullbar, extractors & 2 1/4 exhaust engineered.
Re: got another one.... [Re: 4runnernomore] #1048637 08/02/12 07:50 PM
4x4troy Offline OP
yes every thing bolts right up. it now has a 02 rear axle, front struts,02 non abs brake system...mine was abs now its not but i still have to get a non abs master cylinder. the one on the 02 is for a manual. i do not have pics of the progress but i can post pics later on of the 02 axle in the 95 and the brakes.
Re: got another one.... [Re: 4x4troy] #1048638 08/04/12 01:18 AM
Peabody Offline
Great news on the rear axle swap. I just picked up an axle from an '00 so I can install the lock right-style locker that shipped from Korea. I figured the 28 spline axle assembly was a direct fit in the 26 spline Sporties. But I've thought that a few times with some other mods, only to find that I was wrong. So how did you disable the ABS? Did you just remove the speed sensors? Is it giving you an ABS light on the cluster? Just curious. Looking forward to the updates... <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: got another one.... [Re: Peabody] #1048639 08/04/12 11:31 PM
4x4troy Offline OP
abs light is on...oh well...lol. i removed the and replaced with non abs stuff...master cylinder,front calipers,complete rear axle and the first block right after the mc.brakes are really good now.but have notice my frame is bent so i will be using my 2wd frame under it. but i am going to mod it first.going to lower the strut buckets 2" and drop the arms abount an inch. also going to figure out how to drop the whole ifs about 2"...lots of cutting and welding. but its all fun right.
Re: got another one.... [Re: 4x4troy] #1048640 08/05/12 12:14 AM
4x4troy Offline OP
took it out today..wife drove it some too...
Re: got another one.... [Re: 4x4troy] #1048641 08/07/12 05:00 AM
4x4troy Offline OP
damn drunk drivers...i got hit today and the a-hole did not stop. white ford flatbed early 80's model. my lil kia got messed up. me and alex was in it when it happened.
Re: got another one.... [Re: 4x4troy] #1048642 08/11/12 01:28 PM
4x4troy Offline OP
well . it has new shoes and some body trimming...looks pretty cool but needs more
Re: got another one.... [Re: 4x4troy] #1048643 09/23/12 03:31 AM
4x4troy Offline OP
Re: got another one.... [Re: 4x4troy] #1048644 10/15/12 11:25 PM
4x4troy Offline OP
ok got some stuff done.its all mock up and i still need to cut the ifs stuff off frame..but starting to look good....
Re: got another one.... [Re: 4x4troy] #1048645 12/20/12 08:38 PM
4x4troy Offline OP
had some trouble with my kia...it got burnt up a little. so now I am going to do a rebuild/redsign. the only thing that will be kia is the body and frame. its getting a ford v8(5.0) and auto tranny. a d44 front a 9" rear and will be 4 link front and 4 link wishbone rear. it will run 35's and be exo'd. I am replacing the doors with undented ones and installing new fenders.i will have it looking good. the exo will help keep it that way. it is going to be a long project. got to get my daily driver going first then work starts on the kia.
Re: got another one.... [Re: 4x4troy] #1048646 12/21/12 04:11 PM
DRX350 Offline
Aren't you worried about the weight bias being way off?
I was considering a 3.8 V6 from the late '90s ford or chevy; close to a hundred pounds lighter. Eventually, I came to the conclusion to go turbo instead with a stand alone computer. it will only add about 35-60 pounds and a lot of power...
"Does this part need to be in there?"
1996 Dodge 1500 single cab / short bed, 5.9 4x4; 2" lift (springs not blocks), C.A.I and more mods to come.
Re: got another one.... [Re: DRX350] #1048647 12/22/12 12:36 AM
4x4troy Offline OP
nope going to be a trail toy but still street legal...and the only thing that will be kia will be parts of frame and body.
Re: got another one.... [Re: DRX350] #1048648 01/08/13 02:49 AM
Everet Offline
What is the weight of a Sportage motor? <img src="/forums/images/graemlins/patriot.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: got another one.... [Re: Everet] #1048649 01/08/13 03:45 AM
DRX350 Offline
I couldn't imagine it being much heavier than 275 assembled without accessories...
My 350 block weighed 157lbs totally stripped...
Re: got another one.... [Re: DRX350] #1048650 05/30/13 02:47 AM
4x4troy Offline OP
looking for another one. been out of a kia for to long
Re: got another one.... [Re: 4x4troy] #1048651 09/03/14 05:41 AM
4x4troy Offline OP
well got a 2000 sportage ex 4x4 in very nice condition. will post pics tomorrow
Re: got another one.... [Re: 4x4troy] #1048652 04/01/15 01:42 PM
Dave Scott Offline
Any more on this one?
PHP: 7.4.33 Page Time: 0.010s Queries: 15 (0.006s) Memory: 0.6986 MB (Peak: 0.8628 MB) Data Comp: Off Server Time: 2026-10-21 17:45:51 UTC
