Re: GenI CV Axle Issue
[Re: hazy_daze]
#1048813
07/07/12 03:56 PM
One solution is to use loctite to retain the stub shaft in the passenger side axle extension housing. To remove the extension axle you will have to unbolt the extension housing from the pumpkin.
Or if your not comfortable using Loctite, a retainer ring could be fabbed up to hold the bearing in place. Several people who have LSD units used Loctite on the bearing... I never heard that they had any further problems.
My guess is that the forces on the axle are a lot higher with the locker. Those higher forces increase the friction withing the CV joint. As the suspension travels the force to move extend the joint is higher than the snap ring retaining force, so the snap ring pops out.
I'm sure that the entry angle on the back side of the diff could be a problem.
I would try locking the outer bearing into the housing.
Kevin
[Re: justice]
#1048814
07/07/12 04:18 PM
I removed the shim during reassembly this last time, thinking that would help. And I swapped the Cardone provided inner circlip for an OE # MB526189, which was a bastard to get socked in. If I can't get this fixed, I may just take everything off this one and return it to lightly modified and build another one that has no sentimental value...
[Re: hazy_daze]
#1048815
07/07/12 06:19 PM
...Or...build your own differential drop down system...
[Re: rxinhed]
#1048816
07/07/12 06:47 PM
Along that line, what would it hurt to machine a new center shaft that's a little longer to build an axle off of?
Hmmm....
[Re: Kevin C]
#1048817
07/07/12 07:16 PM
Kevin Cant loctite the drivers side...
99 Gen 2.5, fixing blown head gasket 89 SWB- 33's, ARB Front locker, SR rear locker/axle, SR F brakes, winch, WST Offroad Armor all Around, 2.85 Aussie T-case Gears (SOLD) Sold: (2) 95 SR's, 86 SWB, 90LWB, 91 LWB -Can Change a timing belt in my sleep..
[Re: justice]
#1048818
07/07/12 09:05 PM
Ooops.... My bad. I know that Phill can.
[Re: Kevin C]
#1048819
07/08/12 05:15 AM
Everyone knows what i'm gonna suggest. <img src="/forums/images/graemlins/lol.gif" alt="" />
[Re: LandRaider]
#1048820
07/08/12 01:28 PM
Everyone knows what i'm gonna suggest. <img src="/forums/images/graemlins/lol.gif" alt="" /> That was my first thought. But that's not this truck's purpose. I've been mullin buying yours for wheelin...
[Re: hazy_daze]
#1048821
07/09/12 12:17 AM
the problem seems to be that the shaft is not long enough, and at full droop, you out more stress on the snap ring than it will hold.
The solution would seem to be to make the shaft effectively longer. Is there room to make another groove for the snap ring, further toward the end? How about cutting the shaft and welding in a spacer? Is a gen2 shaft longer? I'll noodle some more...
[Re: fasteddy]
#1048822
07/09/12 01:00 AM
How about machining down the outer face of spocket inside the locking hub to give the suspension more down travel before it starts pulling out on the axle? Simplest solution maybe?
