Page 2 of 4 1 2 3 4
Re: GenI CV Axle Issue [Re: hazy_daze] #1048813 07/07/12 03:56 PM
Kevin C Offline
One solution is to use loctite to retain the stub shaft in the passenger side axle extension housing. To remove the extension axle you will have to unbolt the extension housing from the pumpkin.
Or if your not comfortable using Loctite, a retainer ring could be fabbed up to hold the bearing in place. Several people who have LSD units used Loctite on the bearing... I never heard that they had any further problems.
My guess is that the forces on the axle are a lot higher with the locker. Those higher forces increase the friction withing the CV joint. As the suspension travels the force to move extend the joint is higher than the snap ring retaining force, so the snap ring pops out.
I'm sure that the entry angle on the back side of the diff could be a problem.
I would try locking the outer bearing into the housing.
Kevin
Re: GenI CV Axle Issue [Re: justice] #1048814 07/07/12 04:18 PM
hazy_daze Offline OP
I removed the shim during reassembly this last time, thinking that would help. And I swapped the Cardone provided inner circlip for an OE # MB526189, which was a bastard to get socked in. If I can't get this fixed, I may just take everything off this one and return it to lightly modified and build another one that has no sentimental value...
Re: GenI CV Axle Issue [Re: hazy_daze] #1048815 07/07/12 06:19 PM
...Or...build your own differential drop down system...
Re: GenI CV Axle Issue [Re: rxinhed] #1048816 07/07/12 06:47 PM
Along that line, what would it hurt to machine a new center shaft that's a little longer to build an axle off of?
Hmmm....
Re: GenI CV Axle Issue [Re: Kevin C] #1048817 07/07/12 07:16 PM
justice Offline
Kevin
Cant loctite the drivers side...
Re: GenI CV Axle Issue [Re: justice] #1048818 07/07/12 09:05 PM
Kevin C Offline
Ooops.... My bad. I know that Phill can.
Re: GenI CV Axle Issue [Re: Kevin C] #1048819 07/08/12 05:15 AM
LandRaider Offline
Everyone knows what i'm gonna suggest. <img src="/forums/images/graemlins/lol.gif" alt="" />
Re: GenI CV Axle Issue [Re: LandRaider] #1048820 07/08/12 01:28 PM
That was my first thought. But that's not this truck's purpose. I've been mullin buying yours for wheelin...
Re: GenI CV Axle Issue [Re: hazy_daze] #1048821 07/09/12 12:17 AM
the problem seems to be that the shaft is not long enough, and at full droop, you out more stress on the snap ring than it will hold.
The solution would seem to be to make the shaft effectively longer. Is there room to make another groove for the snap ring, further toward the end? How about cutting the shaft and welding in a spacer? Is a gen2 shaft longer? I'll noodle some more...
Re: GenI CV Axle Issue [Re: fasteddy] #1048822 07/09/12 01:00 AM
justice Offline
How about machining down the outer face of spocket inside the locking hub to give the suspension more down travel before it starts pulling out on the axle? Simplest solution maybe?
Page 2 of 4 1 2 3 4
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6452 MB (Peak: 0.7540 MB) Data Comp: Off Server Time: 2026-05-29 15:27:26 UTC
