Re: 2.6L Transfer Case question. [Re: TOASTY] #1049228 07/18/12 10:15 PM
Instead of asking us the same question over and over, whose answer we are trying to provide, how about answering ours, do you have an AT or an MT?
Another way of answering would be to say that all tcases without a neutral detent, would then also not have a neutral indicator on the shift knob. Kind of thought that would have been clear from the previous replies...
Re: 2.6L Transfer Case question. [Re: MontyMcV] #1049229 07/18/12 10:27 PM
Chill out guys. It's only his 7th post and he may not be familiar with the etiquette here.
I suspect it was originally a manual which he swapped in an automatic since he indicated his replacement transfer case has a neutral detent and he encounters the problem where it goes into neutral.
But as has been asked, we also need to confirm what transmission you have now (see what I mean about putting the details in the signature <img src="/forums/images/graemlins/wink.gif" alt="" />).
Re: 2.6L Transfer Case question. [Re: Pajero_86] #1049230 07/18/12 10:53 PM
I've owned several. All the m/t's had the marking, but some of the a/t's did too, so that's not an indicator.
I don't think it's the shifter. Sometimes the check balls that engage the detents on the shift rails are missing. The shifter is just a lever and pivot that engages forks on the shift rail, and will not affect staying in gear. I'f pull the plugs and check the detent balls and springs.
Re: 2.6L Transfer Case question. [Re: fasteddy] #1049231 07/19/12 07:36 AM
LandRaider Offline
As far as I know ALL Gen 1 manuals have a neutral spot, and ALL Gen1 autos do not.
I'm sure someone could put a shifter handle from a manual into an auto though.
You've got other issues with your transmission dude. <img src="/forums/images/graemlins/frown.gif" alt="" />
Re: 2.6L Transfer Case question. [Re: off-roader] #1049232 07/19/12 01:33 PM
I recant. Had a bad couple of days at work... Anyone who uses Pajero in his screen name deserves a fair shot. <img src="/forums/images/graemlins/cheers.gif" alt="" />
PHP: 7.4.33 Page Time: 0.009s Queries: 15 (0.006s) Memory: 0.6164 MB (Peak: 0.6975 MB) Data Comp: Off Server Time: 2026-06-07 05:59:40 UTC
