rebuild kit 4d55 #1049671 08/03/12 12:44 AM
goobuds Offline OP
I put a custom kit together, which would run you $371.73 + $19.95 shipping. The pistons are available in standard and .020 over.
Kit would include:
4 REPC RY6314 PISTON AND RING ASSY
1 REPC 4B1136 ROD BEARING SET
1 REPC 3C9963 CAM BEARING SET
1 REPC 09-00010 FULL GASKET SET
1 EPGT TB091 Timing Belt
1 CLEV MS1430P Main Bearings Sets
1 FM 4-68304Y Piston Pin Bushing S
1 EPGT TB092 Timing Belt
owned a few .. current 86 rustbucket 2.5td . manual hubs
Re: rebuild kit 4d55 [Re: goobuds] #1049672 08/12/12 02:50 AM
rollguy Offline
Wow! where was this when I needed it 4 months ago? I had to find a used engine to get the pistons from (had 3 bad ones in the engine I was having rebuilt). It would have been nice to get new pistons, rather than cannibalize a rebuildable core. I also had a hard time finding a complete gasket set. Finally found one, but pricey. Your kit seems like a great deal! You should also put in your title that it is for sale.
All Diesel Fleet:
1985 Mitsubishi 2.3 Turbodiesel Pick-up, 1983 GMC Van- 6.2 Diesel.
Benzs: 1995 E300 diesel, 1980 300SD, 1982 300CD, 1983 300D, 1985 190D.
1980 AMC Eagle Limited Wagon powered by: 3.6 Litre I6 VM Turbo Diesel Engine (one of fewer than 10 made, only 2 known to still exist)
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5862 MB (Peak: 0.6347 MB) Data Comp: Off Server Time: 2026-06-07 12:56:10 UTC
