Re: Had to replace the Fuel-Filler hose on the 1990 yesterday. [Re: Mudraider] #1050117 12/17/12 06:16 PM
JAVYPRO Offline
Did the same with an OEM hose part#: MB5547777, $60.
Also make sure that you hose the area well, dirt find its ways back there in impresive quantities.
Javy
88 red Montero with the Dakar Special Edition decals, 438,000 miles (As of 7/23/2012) some occational blue puffing but still strong and counting!!! I am going ppsshhh (turbo), Stay tuned =) ...
Re: Had to replace the Fuel-Filler hose on the 1990 yesterday. [Re: JAVYPRO] #1050118 12/17/12 08:35 PM
MarkG Offline
I removed the metal filler neck from the fender. This gave me a bit more working room to get everything apart and back together.
On the small hoses, I did not drop the tank. I changed the ones I could reach.
Re: Had to replace the Fuel-Filler hose on the 1990 yesterday. [Re: MarkG] #1050119 12/18/12 12:23 AM
crazyhal Offline
Is the napa hose flexible? Is your replacement rubbing on the frame? I tried splicing using 2" exhaust pipe and 2" straight water hose but it leaks.
1990 SWB 3.0
Re: Had to replace the Fuel-Filler hose on the 1990 yesterday. [Re: crazyhal] #1050120 12/18/12 02:02 AM
Water hose is not fuel proof, and will rot out. Napa hose is stiff, straight wall, but somewhat flexible.
Re: Had to replace the Fuel-Filler hose on the 1990 yesterday. [Re: fasteddy] #1050121 12/18/12 02:40 AM
sasnydley Offline OP
Napa hose is very heavy duty.
PHP: 7.4.33 Page Time: 0.012s Queries: 15 (0.009s) Memory: 0.6122 MB (Peak: 0.6764 MB) Data Comp: Off Server Time: 2026-07-16 22:47:31 UTC
