Had to replace the Fuel-Filler hose on the 1990 yesterday.
#1050107
08/19/12 07:35 PM
I drove my daughters truck the other day and every time I got out I smelled gas... Sure enough the rubber hose had dry rotted. I went to JY and pulled one off a newer Montero but it had smaller fuel opening (of course I couldn't tell until AFTER I got it off!) I found an old post with a NAPA part #. Off to NAPA I went with my handy droid LOL! The guy at the counter took one look at the hose and said he had nothing... So I asked him to look up the PART # Sure enough he had it. $52 with tax and back in business! The hose was a pain to get back on-I got the sliced up arm to prove it.
Re: Had to replace the Fuel-Filler hose on the 1990 yesterday.
[Re: sasnydley]
#1050108
08/20/12 04:00 PM
Glad she's back on the road <img src="/forums/images/graemlins/kewl.gif" alt="" />
[Re: sasnydley]
#1050109
08/20/12 05:07 PM
Wow, if you didn't have that p/n you would have been screwed! Bet you wish you had Hazy near you instead of that guy.
Have you also checked the other rubber fuel lines? It's very likely they're also pretty near their end of life and will need to be replaced soon.:(
[Re: off-roader]
#1050110
12/14/12 05:21 AM
1990 SWB 3.0
[Re: crazyhal]
#1050111
12/15/12 08:14 PM
You do realize I typed this in August? LOL. let me see if I can find it.
[Re: sasnydley]
#1050112
12/15/12 08:17 PM
2" wire reinforced fuel hose. P/N 1045 at NAPA. The smaller one is a ~3/4". the 2 inch is what you want. It takes some creative coaxing to get in place.
[Re: sasnydley]
#1050113
12/16/12 07:37 PM
sasnydley, I am about to do the same to my 89 SWB, I lose about 1/2 the fuel I try to put into the dern thing. Any tips; did you have to drop the entire tank to accomplish this task? Any hidden bolts that I should know about?  Thank you in advance! Take care
You maybe younger and can run faster, but I am older and have been around long enough to know where all the shortcuts are!
1989 MTs/Dodge Raider SWB V6 5spd - Daily Driver/Work in Progress.....
[Re: RaiderGriz]
#1050114
12/17/12 02:05 AM
I replaced the filler hose on my 89 about 18 months ago. One suggestion I have, would be to take this opportunity to replace the small vent lines at the filler neck. They are easy to get to when the filler hose is out.
[Re: MarkG]
#1050115
12/17/12 03:24 AM
I replaced the filler hose on my 89 about 18 months ago. One suggestion I have, would be to take this opportunity to replace the small vent lines at the filler neck. They are easy to get to when the filler hose is out. Mark did you drop the entire tank?? Thanks!
[Re: RaiderGriz]
#1050116
12/17/12 04:45 AM
No need to drop tank. use lots of silicone spray. slide the hose onto the top connector. Lots of lube. Once you clear the lower connecter, line it up and slide it down and onto the bottom connector. Did I mention lots of lube?
