Page 2 of 6 1 2 3 4 5 6
Re: 95 Front Pads and Rotors Replacement ?s [Re: Grasscat] #1051124 09/09/12 03:29 PM
TheViper Offline OP
You can use a fine flat blade screwdriver to pry up the c-clip and then pull with pliers. The bearing retaining nut can be removed with a drift and light hammer taps.
im sorry for my ignorance but what is a "drift"
A punch.
Do a search for drift tool or punch tool.
ok, so is this what your talking about?
punch set? http://www.harborfreight.com/hand-tools/punches/8-piece-punch-set-93424.html
or these...
http://www.harborfreight.com/12-piece-punch-and-chisel-set-66337.html
1995 Montero SR
Re: 95 Front Pads and Rotors Replacement ?s [Re: TheViper] #1051125 09/09/12 05:29 PM
Grasscat Offline
Yes
Michael j
TreadLightly! Trainer
Re: 95 Front Pads and Rotors Replacement ?s [Re: Grasscat] #1051126 09/09/12 07:54 PM
TheViper Offline OP
I think at this point its best for me to get in there (next weekend) and see what things look like, then ill have a better idea of the questions i need to ask to complete this job.
also, i dont necessarily need to replace the rotors, but since ive had the monty ive never replaced them and i dont know when the last time they were.
The last question id like to ask before i try this job is...will i need to re-grease anything, if so, what? and what type of grease.
thanks for the help
1995 Montero SR
Re: 95 Front Pads and Rotors Replacement ?s [Re: TheViper] #1051127 09/09/12 08:18 PM
I use a black molybdenum hi-temp grease, says Disk Brake on the sleeve / container...I get both packages for dipping and my grease gun.
My use had mostly been highway driving, but you may consider another type of grease if your 'wheelin has lots of water involved.
Re: 95 Front Pads and Rotors Replacement ?s [Re: rxinhed] #1051128 09/10/12 12:44 AM
TheViper Offline OP
So one more question i thought off while researching this...
you remove the lock nut with a drift tool and hammer but how on earth do you retighten it to the ridiculous value of 119ft/lb
1995 Montero SR
Re: 95 Front Pads and Rotors Replacement ?s [Re: TheViper] #1051129 09/10/12 05:26 AM
I have used the time-worn adage of tightening to finger tight, spin the bearing to move everything around inside, then tighten slightly to set the bearing, lock down and go.
However, since I have the Mitsubishi tool for this, I can use my torque wrench now...on these trucks. For my Ramcharger, I'd buy the proper tool, too.
Re: 95 Front Pads and Rotors Replacement ?s [Re: rxinhed] #1051130 09/10/12 08:16 AM
Canyonero Offline
Just going to throw this out there, since my fronts have recently started the dreaded squeal. Looking to get better aftermarket rotors and pads somewhere. Searched EBC but they only offer pads. After hours of looking, it seems OEM is the only way to go unless someone has found a good aftermarket solution for better braking? (Read as UPGRADE, i.e. better braking power)
1995 Montero SR
2" Body Lift
35x12.50x15 Cooper Discoverer STT
Aisins
Re: 95 Front Pads and Rotors Replacement ?s [Re: Canyonero] #1051131 09/10/12 09:27 AM
KrzyDav Offline
Austrailian pads,,, Axxis in think. Real sticky. Had som on a MR2. Old Colt uses them.
dave h.
Re: 95 Front Pads and Rotors Replacement ?s [Re: TheViper] #1051132 09/10/12 03:00 PM
You tighted with the big special socket tool, which should be pic'd in the FSM. Most of use have gotten the GM 6-pin tool (3/4 ton? Can't recall for sure) and ground off four pins. You can get them at most corner parts stores for ~$15.
Re: 95 Front Pads and Rotors Replacement ?s [Re: MontyMcV] #1051133 09/10/12 04:03 PM
WigWiggy Offline
This is what I bought and ground off 4 pins to make it fit. Performance Tool W1270:
http://www.ebay.com/itm/Wilmar-W1270-4-W...k-/120955834267
These were also helpful references when I did mine:
link
You'll have to register with their forum to see this one:
link
98 Montero, 184k.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6435 MB (Peak: 0.7526 MB) Data Comp: Off Server Time: 2026-06-22 06:05:49 UTC
