Re: Using Google to Seach 4x4wire [Re: TOASTY] #1051233 09/12/12 04:52 AM
Update! Kudos to you all for the feedback on how to do a google search. It became obvious that we put the google search box in the wrong spot and most didn't even realize or forgot it was already there (including yours truly) so quick as snot John fixed it by placing the Google Search box more prominently.
Re: Using Google to Seach 4x4wire [Re: off-roader] #1051234 09/12/12 06:16 AM
Kevin C Offline OP
Good discussions... I had not noticed the embedded Google search.
The other part is that no matter how you access it, Google search engine is one of the best and its good to know there are a number of ways to refine your searches.
Re: Using Google to Seach 4x4wire [Re: Kevin C] #1051235 09/12/12 05:33 PM
Good discussions...
Agreed and valuable feedback for the 'wire staff. Let us know how you guys like it.
Kevin, I forgot about it as well.
Re: Using Google to Seach 4x4wire [Re: off-roader] #1051236 09/12/12 06:40 PM
TresMon Offline
Please sticky this. For the mods. And for me. I got far better results searching this way than I did the standard.
Done!
Thanks for posting this. <img src="/forums/images/graemlins/kewl.gif" alt="" />
okay could you sticky the FAQ section then cause I can't find the google search on it.....
--Tres
(John 14:6)
Black 87' Raider
2.6L/Webber 88
5 Speed
Welded front,tight LSD in the rear
Removed bump stops
4'x6' roof rack
10k. Lb. winch on receiver hitch/custom bumper
100 amp alt
CB radio/AC inverter
S.Winch hubs
Enormous RV battery
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6091 MB (Peak: 0.6653 MB) Data Comp: Off Server Time: 2026-05-29 18:44:11 UTC
