Front head lights #1051336 09/12/12 06:56 AM
fokion Offline OP
Due to the proper use of the vehicle <img src="/forums/images/graemlins/smile.gif" alt="" /> the "mirrors" have fade an also made "craks".
what are my options?
note that I have the older version that the front is glass and not plastic that "blurs" and I would like to keep it.
Can I repaint??
What else?
Re: Front head lights [Re: fokion] #1051337 09/14/12 01:24 PM
Everet Offline
I know you can polish the outside plastic. I have done this procedure: headlight restoration and it worked well, however, when I applied the urethane, it didn't come out the greatest. Will re-sand and do the application over later.
Post some pictures of your issue.
Hope this helps a little.
Re: Front head lights [Re: Everet] #1051338 09/15/12 06:47 AM
fokion Offline OP
Thanx
But my problem is not the "glass" outside but the mirror-like surface on the inside...
Re: Front head lights [Re: fokion] #1051339 09/15/12 06:52 AM
4
4runnernomore Offline
Hi Fokion,
if your silver lens is pitted or rusted over unfortunately the only choice is to replace. <img src="/forums/images/graemlins/scared.gif" alt="" />
but think of the improved light output afterwards. <img src="/forums/images/graemlins/kewl.gif" alt="" />
cheers, Chris <img src="/forums/images/graemlins/cheers.gif" alt="" />
97 Sporty, snorkel, K&N filter,chipped, ext forks, 40mm Dob Springs, KYB struts, 35mm Jeep TJ Springs, RAV 4 OME shocks, Kaiser Locker 5.38 R&P's, 1&3/8 body lift, 245/75 R16 D674's Sports steering wheel, bullbar, extractors & 2 1/4 exhaust engineered.
Re: Front head lights [Re: 4runnernomore] #1051340 09/16/12 07:44 PM
Sportege_Panicmech Offline
It is a very risky procedure but if your highly careful you may be able to do this. It is possible to place your headlights in the oven at a low (250?) temp and warm up the 'goop' that holds the lens onto the reflector housing to pull the lens off. then you could clean and remove the chrome paint and possibly respray the reflector dishes. The reason I had pulled my lenses out was simply cause I wanted to paint the chrome outer ring black.. It doesn't sacrifice any light projection but it gives the headlights a JDM look. But as I said, I'm not responsible for you melting your headlights if you do, lol! It's a tricky job but with patience it can be done. If you look at my headlights, you'll notice they are darker than most. There was another guy on here that had the same success as me doing the JDM black mod I cam up with. see the link on my footnote.
Re: Front head lights [Re: Sportege_Panicmech] #1051341 09/17/12 04:09 AM
Everet Offline
Sorry,
Thought you were talking about the lens. Don't know if you can do anything to the highly polished chrome finish inside.
If you do the headlight trick that Panicmech (I am the 3rd guy to do it I guess) IT IS 250F he is talking about NOT C.
Just check them often for the sealant to soften not the plastic.
Re: Front head lights [Re: Everet] #1051342 09/18/12 05:53 AM
fokion Offline OP
I know the prosedure ( an NO iwill NOT hold you responsible if i fry my headlights <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" /> ) since I was looking to the option of Xenon projectors - not only lamps and ballasts - solution that is not my favorable since usualy the beam goes strait to the oposite driver's eyes...
so there IS a "paint" that I can try???
a high reflective paint?
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6184 MB (Peak: 0.7101 MB) Data Comp: Off Server Time: 2026-06-06 21:47:23 UTC
