Page 4 of 12 1 2 3 4 5 6 11 12
Re: 1989 Dodge Raider V6 - High Idle Problem [Re: fasteddy] #1051655 10/12/12 04:03 AM
G
goldenprospector Offline OP
It was a used Throttle Body. I know nothing about the Air Bypass Screw, I'm going to go look it up in the FSM. I think I have the Idle Stop Screw almost all the way out, if were talking about the same screw...sorry for my lack of experience.
So just screw the Air Bypass Screw all the way down?
I'll try the hair dryer trick on the Throttle Body I took off, if I can figure it out.
Thanks for all your help!
1989 Dodge Raider - V6 - Manual - 4x4 - AC - 31" Tires
Re: 1989 Dodge Raider V6 - High Idle Problem [Re: goldenprospector] #1051656 10/12/12 04:22 AM
G
I tightened the Air Bypass Screw, and sorry to say, nothing happened.
Re: 1989 Dodge Raider V6 - High Idle Problem [Re: goldenprospector] #1051657 10/12/12 04:48 PM
G
Just so you all know...
When I start the Raider in the morning it idles at about 1200rpms and slowly works it way up to 1900rpms or so.
When i let it coast in first gear it speeds up to about 2000rpms and then something kicks in and brings it down to about 1250rpms...then somethings kicks in and lets it rise back up to 2000rpms.
Maybe that info might help some one to help me.
Re: 1989 Dodge Raider V6 - High Idle Problem [Re: goldenprospector] #1051658 10/12/12 11:01 PM
geocrasher Offline
Maybe its been covered, but AC solenoid?
http://tidbitsfortechs.com/
Re: 1989 Dodge Raider V6 - High Idle Problem [Re: geocrasher] #1051659 10/12/12 11:41 PM
G
Hey Geo, no one has brought up the AC Solenoid yet...thanks I'll look into it.
I was able to get a hold of the previous owner and he suggested that I have the timing belt looked at professionally. It seems like a lot of work to get into the timing belt, but I think I'm capable.
Before I do, is there anything else that could be tested? And if the timing is off, would that cause a high idle?
Re: 1989 Dodge Raider V6 - High Idle Problem [Re: geocrasher] #1051660 10/12/12 11:49 PM
G
Hey Geo, I'm looking for the AC Solenoid in the FSM but can't find anything. Where exactly is it located?
Re: 1989 Dodge Raider V6 - High Idle Problem [Re: goldenprospector] #1051661 10/13/12 12:52 AM
doesn't have one - isc controls ac idle via a/c sense circuit to ecu
Re: 1989 Dodge Raider V6 - High Idle Problem [Re: fasteddy] #1051662 10/13/12 02:10 AM
geocrasher Offline
Derp, sorry about that. I forgot you've got fuel injection- I was thinking 2.6L carbed when I posted that. Sorry about that.
Did the new hose have any effect?
Re: 1989 Dodge Raider V6 - High Idle Problem [Re: geocrasher] #1051663 10/13/12 02:14 AM
G
Nah, the hose didnt seem to do anything, it was worth a try!
So what does everyone think about the timing belt being the problem?
Re: 1989 Dodge Raider V6 - High Idle Problem [Re: goldenprospector] #1051664 10/13/12 02:29 AM
justice Offline
Highly doubt it...Sometimes a head gasket leaking coolant into the combustion chambers can cause a high idle. How is the coolant level? Do you ever need to add coolant? If so how often?
PHP: 7.4.33 Page Time: 0.014s Queries: 15 (0.011s) Memory: 0.6474 MB (Peak: 0.7545 MB) Data Comp: Off Server Time: 2026-07-17 00:46:51 UTC
