Page 5 of 12 1 2 3 4 5 6 7 … 11 12
Re: 1989 Dodge Raider V6 - High Idle Problem [Re: justice] #1051665 10/13/12 03:40 AM
reset the timing, using the grounded wire...
Re: 1989 Dodge Raider V6 - High Idle Problem [Re: goldenprospector] #1051666 10/13/12 04:31 AM
KrzyDav Offline
food for thought...
Previous owner cleans T.B. and thereby replacing gasket,,,
...(the wrong gasket ,as the right one has been superceded by the wrong gasket no matter where you buy it, except a Mitsu. dealer)....
It has bad vacuum leak high idle <img src="/forums/images/graemlins/scared.gif" alt="" />and leads previuos owner to replace ICS.
In frustration <img src="/forums/images/graemlins/angry.gif" alt="" /> he sells Raider to you with the wrong advice...
You replace T.B. and get a gasket from "anywhere but dealer" and it is not the right gasket ,,,and the gasket leaks causing high idle....... <img src="/forums/images/graemlins/scared.gif" alt="" />................
May I ask where did you get your T.B. gasket and what was the part number of the gasket???????
dave h.
Re: 1989 Dodge Raider V6 - High Idle Problem [Re: KrzyDav] #1051667 10/13/12 04:37 AM
G
goldenprospector Offline OP
Dav, actually I used the old gasket that was from the throttle body I took off. <img src="/forums/images/graemlins/confused.gif" alt="" />
Do you know where I can get the right Gasket from? Or what the correct part number is so I can go find one?
I would love for the problem to be a gasket!
1989 Dodge Raider - V6 - Manual - 4x4 - AC - 31" Tires
Re: 1989 Dodge Raider V6 - High Idle Problem [Re: fasteddy] #1051668 10/13/12 04:40 AM
G
How do I reset the Timing with the ground wire, if you don't mind explaining.
Re: 1989 Dodge Raider V6 - High Idle Problem [Re: goldenprospector] #1051669 10/13/12 04:47 AM
KrzyDav Offline
The dealer is the only place to get the right gasket.
See my "gasket" thread.
You can cut one with a razor out of gasket material.
If you used the gasket that came with the OLD trottle body you bought, """chances""" are you ""might"" have the right gasket.
I'm sorry I don't have the ability <img src="/forums/images/graemlins/notooth.gif" alt="" />to post a picture of the 2 T.B. gaskets side by side so everybody can see what I'm talking about, and how bad a vacuum leak would be with the gasket 'They All' will sell you nowadays...
Timing set: there is a plastic plug with a cover on it mounted above you brake vacuum booster on the firewall. One wire-- yellow/white with black sripe(as I recall)-- goes into that plug. You connect a grounging wire(a wire with alligator clips)to the one terminal found inside that plug.
When you connect it your engine idle speed will drop noticably,,,and that's when your use the timing light and turn the distributor to adjust timing.
But,,,If you have a high idle cause by vacuum leak, cause ECU won't default idle to properly for accurate timing set because it's "confused"....
dave h.
Re: 1989 Dodge Raider V6 - High Idle Problem [Re: KrzyDav] #1051670 10/13/12 07:32 PM
G
Hey Dav, I went and took off the throttle body so I could take some photo's and show you what the gasket looks like.
[Linked Image] [Linked Image]
Does everything look ok?
Re: 1989 Dodge Raider V6 - High Idle Problem [Re: goldenprospector] #1051671 10/13/12 10:03 PM
G
I took off the other piece between the Throttle Body and the Intake Manifold and cut a new Gasket for it. Let me know if it looks ok...I'm planning on using Gasket Sealant on it and was wondering if I should use Gasket sealant on the thin rubber Gasket with the three lumps on it( in the first pictures)...
I know I'm a total rookie so please bare with all my questions.
Re: 1989 Dodge Raider V6 - High Idle Problem [Re: goldenprospector] #1051672 10/14/12 05:47 AM
G
Got the Throttle Body back on and still got a high idle. At this point I'm desperately looking for advise on what I should do next.
I'm going to get a timing light and an alligator clip and see what I can figure out on the timing as soon as I can.
Thanks again for everyones time and opinions!
Re: 1989 Dodge Raider V6 - High Idle Problem [Re: goldenprospector] #1051673 10/14/12 06:07 AM
geocrasher Offline
Have you you considered the possibility that it could be the ECU?
http://tidbitsfortechs.com/
Re: 1989 Dodge Raider V6 - High Idle Problem [Re: geocrasher] #1051674 10/14/12 06:36 AM
G
Geo, I was thinking in the back of my mind that it could be the ECU but with my lack of experience, I really have no clue. I just went and watched a few youtube video's on timing lights and how to adjust the timing with the distributor, but its all kinda overwhelming.
I'm determined to get this thing on the road! And to answer the question about loosing coolant... I haven't had a chance to get it on the road to really see what the coolant is doing, but it seems to be holding just fine.
How would I go about diagnosing the ECU? And do you think the timing belt could be off a tooth? Thanks!
PHP: 7.4.33 Page Time: 0.014s Queries: 16 (0.010s) Memory: 0.6568 MB (Peak: 0.7802 MB) Data Comp: Off Server Time: 2026-11-04 02:32:36 UTC
