Page 6 of 6 1 2 3 4 5 6
Re: !!!! edit:::It's Fixed!!!Re: fast idle,,,mine's caught the disease... [Re: fasteddy] #1052849 03/25/13 04:31 AM
KrzyDav Offline OP
Mud. I emiled 3 emils nd 4 pictures thru yahoo. I'll try again. I rec. the pics in the ccs to myself. I put the T.B pics into photobucket,,,but I don't know computer lingo to understnd how to get them onto the wire.
P.S. on TPS as your problem. You'll get intermitnt light nd no code set,,,which is how mine is cting now.
Eddy,I'm getting red light at occsionl idle nd around 2,500 rpm with under low load. Code 21.
(nd the "-"bc is bd on this 13 yer old LT. My other one tht reds photo card shorts out fter bout 20 min. use.)
I think I'll try opening up the idle needle another 200rpm.
dave h.
Re: !!!! edit:::It's Fixed!!!Re: fast idle,,,mine's caught the disease... [Re: KrzyDav] #1052850 03/26/13 12:01 AM
KrzyDav Offline OP
Mon. test run.
OK , I'm not getting ny check engine light untill engine is fully heated up nd in rod use for 30 min. or so. Then t idle (even with increaseing idle with fast idle screw). Then, still sometimes t mild lod, i.e., driving on level road at and around 2,400-2,800 or so rpm. <img src="/forums/images/graemlins/confused.gif" alt="" />
Oh , nd it's defintely Summertime here, 55o-85o .
edit,,,,
9:pm
messing round with the wiring hrness seems to cuse the light to come on sometimes. Now I'm thinking the terminal has a crack in it or wire cracked that is changing with temps nd vibrations.
dave h.
Re: !!!! edit:::It's Fixed!!!Re: fast idle,,,mine's caught the disease... [Re: KrzyDav] #1052851 01/08/14 02:14 AM
haztoys Offline
Well after playing the TB wax choke dance for some years now..And have had good luck keeping a low idle most of the time... I blocked off the wax choke with a gasket .. Motor realy does idle much smoother..Did get a CEL at hot idle and off gas at 1700rpm on down ... But a adjust of the TPS fixed the CEL..
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.005s) Memory: 0.6037 MB (Peak: 0.6585 MB) Data Comp: Off Server Time: 2026-06-07 07:25:00 UTC
