Page 2 of 4 1 2 3 4
Re: New Member TheRunt313 Write up [Re: Runt313] #1052947 10/24/12 02:06 AM
Runt313 Offline OP
Glamour Pics
Re: New Member TheRunt313 Write up [Re: Runt313] #1052948 10/24/12 01:29 PM
Everet Offline
I've PM'd you about the locker.
Everet
Re: New Member TheRunt313 Write up [Re: Everet] #1052949 10/24/12 03:25 PM
Runt313 Offline OP
Pm recieved!
Re: New Member TheRunt313 Write up [Re: Runt313] #1052950 10/31/12 10:08 PM
Runt313 Offline OP
Hi all!
just a quik update before i go to bed....heavy duty exaust, wild cat extracters and high flow cat are all in! It seems to have fixed the lagg I got in 4th uphill and no stuttering in 2nd with low revz! yippeee! all in all much better more even power thru all gears! better sounding too hope you have a great week
cheers
chris
ps photo's to come!
Re: New Member TheRunt313 Write up [Re: Runt313] #1052951 11/10/12 07:09 PM
Runt313 Offline OP
Hey guys
just a quik note the wild cat extractors are advitised as 95-97 fit but they are direct bolt on.... all that needs changing is the egr valve soldered shut! highly recomended ! great preformance change!
Re: New Member TheRunt313 Write up [Re: Runt313] #1052952 11/24/12 08:57 PM
Runt313 Offline OP
Hi all power chip has been added ps let me know if you need an obd 1 into obd 2 adapter as i found a great site hope you had a good weekend!
chris
Re: New Member TheRunt313 Write up [Re: Runt313] #1052953 12/02/12 04:01 PM
Runt313 Offline OP
Power chip R.I.P.......so the mount for the powerchip is in the engine bay on my 2001 had to find an adapter but not impossible so anyway first serious run and the chip melted "to hot in the engine bay" ;( so no go on the chip it does give the extra power but not worth the melt down...Hope my experience can help others cheers all!
Re: New Member TheRunt313 Write up [Re: Runt313] #1052954 12/02/12 10:37 PM
Peabody Offline
Did you attach it to the OBD port under the hood? I wonder if the port under the steering column/dash would have also worked...
Re: New Member TheRunt313 Write up [Re: Peabody] #1052955 12/02/12 10:43 PM
Runt313 Offline OP
fair call! i did look but couldnt see one where the instructions said it would be on the right of steering colum <img src="/forums/images/graemlins/frown.gif" alt="" /> that wouldve been a much better option!
Re: New Member TheRunt313 Write up [Re: Runt313] #1052956 12/08/12 07:11 PM
Runt313 Offline OP
Hi team!
Just wanted to give a quik update after taking the runt out on one ov the more extreme tracks( which it made it up no probs, while two land cruisers couldnt even attempt the incline!) I had small over heating issue;s as ur doing hi revs in 4L with no air its expected but i need better cooling so custom heavy duty raidator will be in hopefully in the next two weeks ! ill post some pics and keep yall updated hope you had a great week!
cheers
chris
Page 2 of 4 1 2 3 4
PHP: 7.4.33 Page Time: 0.008s Queries: 16 (0.005s) Memory: 0.6335 MB (Peak: 0.7409 MB) Data Comp: Off Server Time: 2026-06-21 18:59:16 UTC
