87 & 88 Raider front end issues
#1053216
10/28/12 01:50 PM
To all Raider owners do you have a good bit of play in your steering components such as the tie rods or upper and lower control arms, I have changed out the upper control arms and still when I get on a rough road the front end sounds terrible, knocking and bumping like something about to come loose, I also changed out the idler arm and still I have this condition. I have a very small amount of play in both front wheel bearings but this just does not seem to be enough to cause this much knocking. The reason I ask if you all have had this condition is because I have a 87 & 88 and both have this same knocking in the front end when I get on rough terrain. If any of you have had this condition let me know what you did to correct or help it. I'm wondering if its just the design on the front end.....thanks for any ones advice
Re: 87 & 88 Raider front end issues
[Re: huntnsonvagun]
#1053217
10/28/12 06:29 PM
You make no mention of checking the shock absorber or sway bar bushings.
[Re: rxinhed]
#1053218
10/29/12 02:30 AM
New shocks, but my right sway bar bushing does have a little tear in it but does not seem bad enough to make the noise I'm hearing, I'll replace it with one off the 88 and see... I'm thinking about replacing all the tie rod ends and see if that will tighten it up..
[Re: rxinhed]
#1053219
10/29/12 02:49 AM
Also I recall where someone mentioned there being an adjustment on the steering pump to tighten it up. Anyone recall if this is the case?
[Re: off-roader]
#1053220
10/29/12 03:20 AM
my truck that has the same basic front suspension has a crazy knocking on the right side and its all checked out good as far as ball joints and tie rod ends...has all new sway bar bushings and front shocks, i cant figure out what it is either
1989 Mighty Max 4WD 2.6 Turbo,Auto EFI...megasquirt! 4.62 Rear LSD! 1989 Mighty Max 2WD 2.6 5 speed slammed 1993 Eagle Talon TSI
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6058 MB (Peak: 0.6708 MB) Data Comp: Off Server Time: 2026-06-10 04:02:12 UTCValid HTML 5 and Valid CSS
