Re: The Raiders new home... [Re: Kevin C] #1053651 11/09/12 06:02 AM
87monty Offline
The best montero lab ever!
2003 limited 20 year anniversary
96 SR
87 Montero SWB=Turbo diesel 4BT
T19 4sd with 205 transfer case
Re: The Raiders new home... [Re: 87monty] #1053652 11/09/12 06:24 AM
stony-man Offline
MAN that's purty. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: The Raiders new home... [Re: stony-man] #1053653 11/09/12 07:36 PM
fixed it for ya...
Re: The Raiders new home... [Re: off-roader] #1053654 11/10/12 12:10 AM
monte Offline
Re: The Raiders new home... [Re: off-roader] #1053655 11/10/12 02:50 AM
Kevin C Offline OP
fixed it for ya...
Nice... Now to get buy in from my wife. <img src="/forums/images/graemlins/rodent.gif" alt="" />
Re: The Raiders new home... [Re: Kevin C] #1053656 11/10/12 04:15 AM
And how do I know Kevin used a roller on the floor?
I like the color...
Re: The Raiders new home... [Re: fasteddy] #1053657 11/10/12 10:20 AM
LandRaider Offline
Re: The Raiders new home... [Re: fasteddy] #1053658 11/10/12 04:21 PM
Kevin C Offline OP
I like the color...
I sure wasn't going to use a paint brush and 100% solids epoxy does not spray very well. For the first coat I used the rollers supplied with the kit. The nap was too long and they bunched up a bit.
I rented a floor sander and sanded the first coat smooth. Kind of like when you sand between coats on a car. I spent three days getting it right. I went through in a couple of spots and had to re-coat. And just like a car I used heat lamps and a DA to feather it it.
I used a higher quality short nap roller for the clear coat. That ended up a lot smoother. The only issue in the final coat is the supplied ant slip glass was pretty coarse that sticks up like pimples.
I should have used a thinner final coat. That would have allowed me to use a finer anti skid. In a couple of years when this one needs to be cleaned up I will probably sand the clear coat smooth and put a fresh clear coat of polyaspartic on top.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6343 MB (Peak: 0.7342 MB) Data Comp: Off Server Time: 2026-05-29 23:49:13 UTC
