Got a question about a 1990 LWB Montero rear axle. #1053803 11/12/12 02:00 AM
Devilmontero Offline OP
I've searched and I haven't found anything. I'm new to monteros but not to offroading. My first question is I have a 1990 Montero LWB with coil springs and was wondering what rearend is in it and is it strong. My axle seals are leaking and was wondering if I should fix or try to find a Gen 2 SR. Im not going to be hard core offroading with this vehicle.
1990 LWB 3.0 Auto Tan interior Mostly Stock 194k
Re: Got a question [Re: Devilmontero] #1053804 11/12/12 02:05 AM
Welcome to your first post.
There is nothing wrong with the Gen I rear axle, you already own it. The seal is not too difficult to replace and is much less work than swapping in a Gen II axle. I won't go into the Gen II axle topic too much, because there are numerous threads documenting them. The benefits are a wider track, disc brakes and an air-locker (not like ARB).
I'd just replace the seal and wheel bearing, turn the drums, adjust your brakes and be done the same day.
Russell
Re: Got a question [Re: rxinhed] #1053805 11/12/12 02:09 AM
Gen 1 v6 axle and ring gear are plenty strong and with a more powerful engine, the gen 2 SR is even bigger/stronger design. For the stock pose plant, the gen 1 rear drivetrain is plenty strong enough. Be sure to upgrade the trailing arms though.
Re: Got a question [Re: off-roader] #1053806 11/12/12 02:32 AM
Thanks guys. One more question. Can you tell me what the rearend is. It looks like a ford 9" but I know it's not.
Re: Got a question [Re: Devilmontero] #1053807 11/12/12 02:44 AM
Nope it's not. From what we've been able to learn in over a decade of research is they're a Mitsubishi Gearset. No other vehicles use them.
That said IIRC the Gen 1 v6 is at least ~8.5" ring gear while the 3.5l Montero's a have a 9.5" ring gear.
HTH
Re: Got a question [Re: Devilmontero] #1053808 11/12/12 02:47 AM
KrzyDav Offline
it's a 9" MMC or KOYO , I'm not real sure on what plant the axle is built in, all I know is you can't break it or wear it out. Many came with LSD . Look for orange sticker in drivers door jam. The LSDs last forever, too.
Ratio is 4.625,,,that info and more is on a tag near radiator.
dave h.
Re: Got a question [Re: off-roader] #1053809 11/12/12 03:25 AM
I really appreciate it. Guess I'll be ordering some axles seals next week
Re: Got a question [Re: Devilmontero] #1053810 11/12/12 03:29 AM
Welcome to The Wire. Read the posting guidelines thread. My answer to your subject would be "Got an answer..." Seriously though, you want people to read your thread. A bad topic doesn't help your pursuit.
PHP: 7.4.33 Page Time: 2.343s Queries: 15 (0.005s) Memory: 0.6253 MB (Peak: 0.7240 MB) Data Comp: Off Server Time: 2026-06-18 10:48:45 UTC
