Re: Lifting Mighty Max
[Re: rxinhed]
#1053970
11/19/12 06:32 AM
take the flaires off and sell them to me, i just want them for the appearence.
1989 Mighty Max 4WD 2.6 Turbo,Auto EFI...megasquirt! 4.62 Rear LSD! 1989 Mighty Max 2WD 2.6 5 speed slammed 1993 Eagle Talon TSI
[Re: boostin]
#1053971
11/19/12 06:48 AM
woah rxinhed , they made ext cab mighty max? that is sweet i'm jealous.
anyway does anyone have suggestion for what shackle length to order, and a good place to get one? and also how far I can crank the torsion bars? and i'll check for any monteros at the junk yard for upper control arms. anything else I can look into? I thought I read rancho 5000s would get the front up a bit?
[Re: awc737]
#1053972
11/19/12 10:54 PM
So my junkyard has 2 Gen II monteros, a 98 sport and a 95 SR with the rear axle and locker... which I'm considering.
Although, if I grab the upper control arms thats gonna lift my front? Any other parts I could take form the IFS?
[Re: awc737]
#1053973
11/20/12 02:00 AM
so lucky up here in canada we never have any 4wd mitsus in auto wreckers
[Re: awc737]
#1053975
11/20/12 10:30 AM
Back when I had a Toyota pickup I used 4crawler shackles, and Roger made them about 9" long for me to both fix sagging springs AND lift it. Had to take one of them to a grinder to get the bushing to fit (they were a smidgen narrow) but that being said, I'd still use them again. Great product, great guy.
[Re: geocrasher]
#1053976
11/20/12 05:25 PM
Thanks geocrasher. Why does everyone say to get shackles off the FRONT of a toyota? According to this the fronts are offset: http://www.trail-gear.com/shackles , that doesn't sound right. Oh and before I waste time pulling, no one seems to be real clear on this: Will upper control arms from Gen II Montero give me any height? Is there any component of the IFS I can pull or order that will?
[Re: awc737]
#1053977
11/21/12 02:28 AM
i am wondering if the gen 2 upper control arms would even fit?
according to asa the truck and gen 1 montero are different part nubers
[Re: boostin]
#1053978
12/09/12 12:13 AM
I sure hope they fit, because I ripped Gen II montero UCA out of the junk yard. I plan to crank torsion bars all the way an trim the bump stops, and replace the UCA's. For the rear I got some really cheap looking universal shackles at Auto Zone , I will try them out...
[Re: awc737]
#1053979
12/15/12 11:10 PM
I did not end up using the Montero UCA's. I cranked the torsion bars as tight as they would go, and it came up just under 2". like 1.8". I was very happy with the ride still, so I saw no point. Then we put on these universal shackles from Orielly: ![[Linked Image]](http://i.imgur.com/QRmPm.jpg) I need bigger tires. 35's would probably fit nice, but I'll run 33's until I get some differentials or axles from a Montero. Next I'll be putting front / rear bumbers and rollbar from a Toyota I already picked up.
