Re: Another 95 SR Broken Crank Bolt - Mine
[Re: ryany]
#1054130
02/14/13 01:16 AM
Mullets take time. I already drink Busch, though, and I have several t-shirts I could cut the sleeves off of.
[Re: JohnnyBfromPeoria]
#1054131
03/10/13 02:35 AM
Two E-Z Outs broke on us today. It's open-engine surgery at this point. I have options, thanks to the AZ Crew!
#1054132
03/10/13 02:43 AM
Two E-Z Outs broke on us today. <img src="/forums/images/graemlins/zombie.gif" alt="" /> We're they quality units or harbor freight units? It's open-engine surgery at this point. I have options, thanks to the AZ Crew!
John B. No kidding! <img src="/forums/images/graemlins/kewl.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" />
[Re: motero]
#1054133
03/10/13 04:01 AM
Keep at it JB, If you get desperate give me a call and I will explain what to do with one of these "screw head file". <img src="/forums/images/graemlins/ignore.gif" alt="" /> Before you open it up you want to give it one last shot?
99 Montero....15mpg! Sold (so sad) 02 Jetta TDI....48mpg! 03 2500 Ram QCLB Cummins....18mpg 02 2500 Yukon XL, We out grew the montero, at least it has one locker.....13mpg (sold) 01 montero limited
[Re: motero]
#1054134
03/10/13 06:25 PM
Problem here at this point is the E-Z outs are busted off inside the crank snout. At this point we were talking about pulling the motor and replacing the crank. Or we would have to see what a machine shop would charge to try and repair.
What is your advise Motero? Keep in mind though, not only is there the remains of a bolt but now we have broken tips of E-Z outs in there.
[Re: motero]
#1054135
03/10/13 06:39 PM
Motero, I'm not sure there's anything left to try, but if you can think of something, I'm all ears. The bolt simply wouldn't budge any more.
Doesn't really matter that the E-Z's were Harbor Freight at this point. If there was any way to turn that bolt, that was it. It took an incredible amount of force to break those things and the bolt just shrugged it off.
Still contemplating things. I do believe it's time to get the '86 back in action, though, as I'm tired of being OUT of action! Onward!
#1054136
03/11/13 01:22 AM
There is a possibility that the threads are destroyed in there anyway, it will take a tungsten drill bit to remove the easy out. I sent you a text, I may be able to salvage the situation I just might be an expert on this sort of thing.
[Re: TOASTY]
#1054137
03/11/13 02:29 AM
There is a possibility that the threads are destroyed in there anyway, it will take a tungsten drill bit to remove the easy out. I sent you a text, I may be able to salvage the situation I just might be an expert on this sort of thing. What's your plan? Weld on a stud so you can remove it?
[Re: off-roader]
#1054138
03/11/13 04:26 AM
yeah, it seems someone is always bringing me something with a bolt broken off deep inside or a broken tap.
[Re: TOASTY]
#1054139
03/11/13 10:35 AM
There is one other way, and its a last ditch effort, but I've seen it done and it was successful. Acetylene torch. Hot flame quickly applied directly to the bolt(put snout of torch in the hole), and it will "pop" the bolt and pretty much vaporize it. The bolt has lower melting point than the crank, so you need to be quick about it. Don't ask me how I know this...but at this point what do you have to loose? The one time I witnessed this it was on a 95 SR that had a drill bit broke off in the bolt, and the threads of the crankshaft amazingly were unharmed after the procedure. The old guy that did it was experienced in this method and he said its dangerous for the threads, but it worked in that case.. Good Luck.
99 Gen 2.5, fixing blown head gasket 89 SWB- 33's, ARB Front locker, SR rear locker/axle, SR F brakes, winch, WST Offroad Armor all Around, 2.85 Aussie T-case Gears (SOLD) Sold: (2) 95 SR's, 86 SWB, 90LWB, 91 LWB -Can Change a timing belt in my sleep..
