Buzzing sound from ECU when starting the engine !!! #1054301 11/23/12 02:29 AM
3
3esso Offline OP
Hi Guys
Recently this issue started developing with my car: 1996 SWB 3.5 equivalent to the SR in the US
while attempting to start the engine once I move the key to hit the starter motor, a Buzzing rely sort of noise is heard from the ECU on the kick panel on the passenger side. the starter would not kick in unless I back of and just hit the starter again and it would start normally.
now this issue has not yet developed into a problem, but this being the ECU I thought there might be something to do with it before it gets worse, or the ECU fries.
This issue has no pattern to is what so ever, it happens early in the morning as well as just restarting the engine at the petrol station, cold days & hot days also.
Is this a Serious issue yet? is there something to be done to fix this?
96 NJ SWB 3.5 pajero(Bone stock)
84 NA Hi-roof Pajero(also Stock)
Re: Buzzing sound from ECU when starting the engine !!! [Re: 3esso] #1054302 11/27/12 02:10 AM
ES_97Sport Offline
Unless I'm mistaken, all the fuel pump control stuff is there, too. Just like in the Sports (Challengers). That is almost certainly not the ECM. Sounds like the fuel control relay stuff to me.
Re: Buzzing sound from ECU when starting the engine !!! [Re: ES_97Sport] #1054303 11/30/12 01:35 PM
3
3esso Offline OP
But the motor would not crank and starter wont kick in
is that related?
Re: Buzzing sound from ECU when starting the engine !!! [Re: 3esso] #1054304 11/30/12 05:33 PM
P
pcc Offline
Isn't there an ECU relay?
Re: Buzzing sound from ECU when starting the engine !!! [Re: 3esso] #1054305 12/11/12 08:37 PM
ES_97Sport Offline
is that related?
Are you ABSOLUTELY SURE the noise comes from inside? The starter is right there on the outside of the firewall and a noise from it can sound like it's coming from the kick panel. I re-read your post a couple times. I think you'd be best off checking out the starter and solenoid before tearing into the wireing and control units. I've had starters make a 'buzzing noise' that sounds like it's coming from inside the cab and had the same thing happen as you describe.
Re: Buzzing sound from ECU when starting the engine !!! [Re: ES_97Sport] #1054306 12/11/12 10:28 PM
justice Offline
The ignition switch on the Gen2's have been known to fail causing it to be intermitant. Just something to look at. It screws into the back of the key tumbler with 2 screws. You can access it by removing bottom part of the steering column cover.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6121 MB (Peak: 0.6825 MB) Data Comp: Off Server Time: 2026-06-13 13:18:38 UTC
