Re: Opinions needed on high mileage 95 Montero SR
[Re: ryany]
#1054872
12/09/12 10:16 PM
I'm not confident in my abilities or tools to pull of this type of repair myself.
Any idea what it would cost to get a shop to do this work?
[Re: RobG4]
#1054873
12/09/12 11:02 PM
Don't let that stop you. I didn't know SQUAT about any serious mechanical/engine work when I bought my SR. Thanks to this forum, and some local guys in the AZ crew, I know my way around this engine quite well now. Granted that was due to unknowingly buying a truck with a junk engine, but I was determined to get it back on the road. A crank bolt change is not hard at all. As long as you catch it before it breaks, that is.
1995 Montero SR 2" Body Lift 35x12.50x15 Cooper Discoverer STT Aisins
[Re: Canyonero]
#1054874
12/09/12 11:49 PM
Rob, where in GA are you?
[Re: fasteddy]
#1054875
12/10/12 12:41 AM
I'm in Athens fasteddy, you down near Perry?
Thanks for the replies guys. One of the things I look forward to with the vehicle I get is learning how to work on it, and the process of modding and maintaining it myself.
I haven't pulled the trigger on this truck yet so I'm taking this repair into consideration before making an offer. From what I can tell, the last timing belt change was done at an independent repair shop, which may or may not have replaced the crank bolt.
Sounds like if I buy this truck it should be one of the first things I do.
Should I replace the timing belt at the same time? Just to get it done and know its done?
The seller also says that in 4 Lo, the CV axle on drivers side makes a clicking noise. he doesn't know if it just needs a boot replaced or ??...He doesn't drive it much in 4 Lo any more. Any thoughts?
[Re: RobG4]
#1054876
12/10/12 01:07 AM
That truck isn't due for a timing belt for another 30k miles, and the timing belt replacement on this engine is a pretty significant endeavor (there's a very thorough write-up about it in the how-to section of this forum), so you don't really want to dive into that if it's not necessary. Changing the crankshaft bolt is pretty simple really, removing a few items for access and finding a way to prevent the crankshaft from turning when you torque the new bolt to spec would be the only challenges - assuming you have the proper tools it could be done in less than 30 minutes. I'd give it a 3 on a 1-10 difficulty scale.
95 Montero SR 3.8 MIVEC, Advance headers, 2 1/2" exhaust, Magnaflow muffler, OME shocks & rear springs, 2" body lift, 3" tank lift, 4.90s, TRE front locker, factory rear locker, Roger Brown Rock Sliderz, 315/75r16 (35") tires, Sport big brakes
[Re: ryany]
#1054877
12/10/12 02:07 PM
Maintenance is key. I have 205k on my 99. If it was serviced properly, then I wouldn't worry. Good luck
