questions on lifting gen 1 swb with ome torsion etc..
#1054983
12/11/12 08:21 PM
I'm putting togehter everything to get my gen 1 swb lifted. Right now im sitting stock on 33. I noticed one of my otsion bars looks completely maxed out and the other has quite a bit of adjustment. I have no idea why as it was a bone stock rig before I bought it.
Anyhow right now I have the toyota shackles.
I was planning on buying the ome springs with the 1.5 lift, but I dont know which spring rate to get, I assume the softer though?
OVERALL HOW MUCH LIFT AM i LOoking at between the shackles and the springs?
What can I do to compensate for the lift in the back with the front?
I also plan on installing a gen 2 sr locker, and a v6 front end as I am running a 87, along with an arb locker, although I doubt any of this will affect the lift.
8 Starion SHP, 87 mitsubishi van, , 81 galant g54bt, 78 lancer g54bt, 1965 Mitsubishi Debonair Deluxe 87 swb montero offroad pkg goin g54bt with sr locker 33x12.5 dual bouncy.
Re: questions on lifting gen 1 swb with ome torsion etc..
[Re: airbats801]
#1054984
12/15/12 06:39 PM
whether cranking the stock TB's or getting new ones, you are only going to get a max of 2in lift in the front. Main problem is that you are going to be sitting on the bumpstops after cranking. Most of us trim the bumpstop(cut in half)to compensate. OME springs are supposed to give you 1.5in (I actually just bought the softer ones myself but have not yet put them on) and I think the Toyota shackels, if you got the stock ones, add about .5in lift. The stiffer OME rear springs are to be used if you are hauling an extra 500lb consistently or towing (according to ARB website)IIRC. For the stock TB's, it's possible one is maxed out because it was removed and not put back correctly. You might try removing them and re-index them or set them up with stock specs. Look up how to do it on here because you want to make sure and do it correctly (for safety reasons). Hope this helps.
'88 Raider. 2.6L dead...2.4L swap in progress, AT, 33's, 2 bouncy seat,AC, CC, 2.25 exh, 2" Tbar, 2" BL, rear DB, rear LSD,4.90's, SW hubs,gen2 uca's, KYB shocks, snorkel, elec fan, MSD.
'99 chev k3500 crewcab '15 Subaru XV '03 BMW i325
[Re: airbats801]
#1054985
12/15/12 07:34 PM
I also plan on installing a gen 2 sr locker, and a v6 front end as I am running a 87, along with an arb locker, although I doubt any of this will affect the lift. The SR rear axle only comes as a coil spring system. I hope you know you'll need to remove the original coil spring perches and weld on leaf spring perches. Alternatively IIRC, some of the sports with lockers are made for leaf spring suspensions. <img src="/forums/images/graemlins/kewl.gif" alt="" />
[Re: off-roader]
#1054986
12/15/12 08:46 PM
I'm guessing he's speaking of the Montero Sport axel swap which came with leaf springs.
