Re: Any issue with 10.5s on stock pomegranates?
[Re: SenorCarey]
#1056023
01/16/13 02:58 AM
I ran Michelin all terrain 31x10.5's on my stock Raider wheels for years without loss of stability or abnormal wear of any type. And I would probably try to hang with FastEddy in those corners, too, as I used to push it until the tires slid or I felt one lift off the pavement.
The tires lived on for several more years on another AZ Crew vehicle after I moved on from them.
[Re: JohnnyBfromPeoria]
#1056024
01/16/13 03:40 AM
I have ran 33x10.5x15 BFG Mud terrains on the 1990 4dr LS with the stock Pommies. I actually thought they were 7inch rims??? I never had any issues, I did after a time put 11/4" wheel spacers on -more for looks than stability- but it did both. I now have 32x11.5x 15's on truck- personally I like the 33x10.5x15 tire better on it. My 95 has 31's on it's stock wheels.
[Re: SenorCarey]
#1056025
01/16/13 04:22 AM
So I'm reading correctly 12.5 will work on pommies?
SOLD!!: 91 LS 95 SR Rear LSD front 95 LS front brakes Dons Bumper 10k Gorilla/Promark winch Safari Snorkel Dual bouncy 31's
1991 Chevy Suburban 33's. All other stock.
[Re: willwinchforfood]
#1056026
01/16/13 07:52 AM
NO...way too narrow... <img src="/forums/images/graemlins/zombie.gif" alt="" />
#1056027
01/16/13 02:42 PM
So I'm reading correctly 12.5 will work on pommies? Seen a guy on here do it once. Unkown as to the long term verdict was.
99 Gen 2.5, fixing blown head gasket 89 SWB- 33's, ARB Front locker, SR rear locker/axle, SR F brakes, winch, WST Offroad Armor all Around, 2.85 Aussie T-case Gears (SOLD) Sold: (2) 95 SR's, 86 SWB, 90LWB, 91 LWB -Can Change a timing belt in my sleep..
[Re: rxinhed]
#1056028
01/16/13 03:06 PM
Dang iphone, I meant 11.5?
#1056029
01/16/13 03:52 PM
Dang iphone, I meant 11.5? My 32-11.50/15's went on with no problem.
[Re: jdavis]
#1056030
01/17/13 02:40 AM
I mounted 33x10.5 BFG KM2s on my Raider, front no rubbing, the rear with the wider than stock SR axle has zero rubbing issues at all. <img src="/forums/images/graemlins/kewl.gif" alt="" /> ![[Linked Image]](https://sphotos-b.xx.fbcdn.net/hphotos-snc6/182505_10152196020705643_375836090_n.jpg)
Richard E 1989 Montero - Stock-ish 1989 V6 Auto Raider - 5.3 Vortech Swap. 1987 Mitsubishi Starion 2.6t, soon to be 3.5 1983 Honda XL600R
[Re: StockRaider]
#1056031
01/17/13 04:03 AM
I mounted 33x10.5 BFG KM2s on my Raider, front no rubbing, the rear with the wider than stock SR axle has zero rubbing issues at all. <img src="/forums/images/graemlins/kewl.gif" alt="" /> That disc brake axle is the shizznit isn't it? Stop on a dime and get change.
[Re: Mudraider]
#1056032
01/17/13 05:02 PM
Firstly most importantly, that Red Raider looks sweet. I like them clean like that. Secondlly and most awesomly, I ran a really hardcore trail here in north Ga with the disc brake axle installed. I dont think I would have had near the control and confidence on the trail without it. If i can find a leaf spring locker out of a sport Id stick it under my 84 asap.
