Re: 95 SR bad vibration 45mph+ [Re: hochkis] #1056163 01/18/13 03:49 PM
METALMOVER Offline
Does it clunk when you put it in reverse or drive?Give it a little gas with foot on brake and shift from reverse to drive a few times if your getting a clunk between the shifts its u joint, also someone can look underneath and see if the driveshaft is "jumping" if so u joints,did you answer if your getting a pulse in your brake pedal when braking at higher speeds? Also could it be a out of balance or bent drive shaft?METALMOVER
1987 Raider,2.6,mt,78"Meyer snow plow,100lb. Doberman alarm,weber carb, lockouts from here- 1989 V-6,SWB, A.T. 4x4, 31'S
Re: 95 SR bad vibration 45mph+ [Re: METALMOVER] #1056164 01/18/13 05:17 PM
hochkis Offline OP
No pulsing in the brake pedal. I do get a bit of a clunk going from drive to reverse. I'm going to go ahead and order some new U joints.
95 Montero SR- Stock
90 Turbo Miata - TD04 wrx turbo, Flyin miata suspension, Torsen diff, 225 RS3's
92 Mighty Max 4x4 - Retired
Re: 95 SR bad vibration 45mph+ [Re: hochkis] #1056165 01/18/13 05:32 PM
METALMOVER Offline
Sounds like the issue, dont know if yours come serviceable with a grease zert but if they do, dont forget to grease em, did that once on my wrangler and they only last about 5oo miles ughhh.METALMOVER
Re: 95 SR bad vibration 45mph+ [Re: METALMOVER] #1056166 01/18/13 07:32 PM
hochkis Offline OP
The ones on there currently are greasable, We'll see if the new ones are.
Re: 95 SR bad vibration 45mph+ [Re: hochkis] #1056167 01/19/13 03:13 PM
sasnydley Offline
May sound silly but have you greased it? You said it had grease fittings. Also does your truck have a locker? If so is it possible that it is stuck locked?
Re: 95 SR bad vibration 45mph+ [Re: sasnydley] #1056168 01/19/13 04:29 PM
ryany Offline
I've run into u-joints that weren't loose, but had worn into a pattern where when moving the joint it felt like it had a detent in one postion. Not moving smoothly through it's range of motion could give you a vibration without any significant looseness in the joint.
95 Montero SR
Re: 95 SR bad vibration 45mph+ [Re: sasnydley] #1056169 01/19/13 07:41 PM
hochkis Offline OP
I did grease them after it was brought up here. no change.
I doubt the locker is stuck as I don't get any tire screech on slow corners or anything.
And I am able to turn on the locker although it appears to have a leaky actuator as the pump keeps turning on every few seconds. <img src="/forums/images/graemlins/barf.gif" alt="" />
Re: 95 SR bad vibration 45mph+ [Re: hochkis] #1056170 01/24/13 12:25 AM
hochkis Offline OP
Anyone know for sure if a 95LS 3.0 and a 95SR 3.5 have the same rear driveshafts? Because I had a spare driveshaft for my old truck (the 95LS) in storage can I just swap them?
Re: 95 SR bad vibration 45mph+ [Re: hochkis] #1056171 01/24/13 05:08 AM
hochkis Offline OP
After Looking closer It's a no, Looks like the flange on the rear axle is different. And atleast the "lip" on the trans side is different, can't confirm the splines as I didn't want to dump fluid on the driveway.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6330 MB (Peak: 0.7194 MB) Data Comp: Off Server Time: 2026-06-07 05:59:45 UTC
